I feel asleep with my arcos on when I woke up - it had now power it seeme dead. I have checked to see if needed charging but when I put it in the charger no reaction. Please help. Could the battery have died or the hard drive???
SOURCE: Archos 504 RESET button
Hi - You can download the manual from the link underlined in blue below:
Archos 504
Se page 7:
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Archos 504 160gb wont start
Take the battery off, and to the left of the battery connetion tabs is a small gold button, push and hold for 10 seconds. It should start up after doing this.
SOURCE: My Archos 504 will not power up.
Press the Reset button on the inside of the unit with the battery removed. This should solve the Problem. If not you may need to send it in.
Reset button is located under the battery. So remove the battery and loo for the button at the end of the archos where the battery pins make contact. To the right of those and half way down between the pins and the case of the hard drive will be a gold round looking circuit. this is the reset. Press it and off you go.
Thanks,
Ed
SOURCE: Archos 504 hard drive upgrade
