The lithium iron battery for this conputer is 4000 mA/hrs. or 4 Ampere hours. That means that with a draw of 1 Ampere the computer would be useable off the battery for 4 hours. Since you can't run off the battery below a certain voltage you can deduct 20% leaving a battery life of a little over three hours.
Testimonial: "thanks for your expert opinoion. i hope you can suggest a compatible battery that would last for 3 hours atleast for the compaq presario CQ41-207AU"
Maybe a battery from this site will help, but check the capacity (Amp/hr) of your current battery first. The length of time a battery lasts is very dependent on how you use the computer. that is If you use the drives a lot, the battery will go flat sooner.
http://www.notebook-laptop-batteries.com...
NO thats about the best you can get really. The best thing is to adjust your power profile to get the best battery life, also Charging it up, should always be done, Over night,if possible, whenever you use ON Battery alone, Recharge, the battery up each, night, try and develop a "Cycle" this will help lengthen the life of the battery.
SOURCE: drivers for compaq presario v3611au
try formatting the system if not download the drivers online
SOURCE: Compaq presario r3000 amd athlon laptop cuts off after 10 minutes
from my experience this might be one of two things...
if it's shutting down while you're installing windows, i'm thinking you might have a problem with the motherboard channel for your CD drive. i saw this happen to a computer at work - we couldn't install windows because it cut off halfway through and blue screened on us.
it might also be a case of a bad hard drive, if you have any testing utility like drive fitness test i'd give that a shot. it sounds like a new one, but they're bad out of the box sometimes.
hope this helps
SOURCE: Winxp Drivers For CQ45-112AU or CQ45-106AU
in compaq cq 45 112au fingerprint reader not working with windows xp pro with sp3
Part Number:
Aspire5535 Aspire 5535
Feature
Description
Part Number
Varies by specifications
Processor / Speed
AMD
Turion™ X2 Ultra dual-core mobile technology
ZM-80/ZM-82/ZM-84/ZM-86/ZM-88 (2 MB L2 cache, 2.10/2.20/2.30/2.40/2.50
GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology,
or
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1
MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD
HyperTransport™ 3.0 technology, or
AMD Athlon™ X2 dual-core processor
QL-60/QL-62/QL-64 (1 MB L2 cache, 1.90/2/2.10 GHz, DDR2 667 MHz, 35 W),
supporting AMD HyperTransport™ 3.0 technology.
Core Logic Chipset
AMD M780G Chipset.
System Bus Speed
667 MHz.
RAM / Max RAM
Up to 2 GB of DDR2 667 MHz memory, upgradable to 4 GB using two soDIMM modules.
Video Subsystem
ATI
Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of
dedicated system memory, up to 1792 MB of shared system memory),
supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR)
technology, Shader Model 4.0, Microsoft® DirectX® 10.0.
LCD Properties
Display 15.6"
HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer
CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via
Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time.
Hard Disk Drive
120/160/250/320 GB or larger hard disk drive.
Optical Drive
8X DVD-Super Multi double-layer.
Battery, Primary
48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use.
Sound Subsystem
Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone.
PCCard Support
1 ExpressCard™/54 slot.
Pointing Device
Touchpad
Peripheral Subsystem
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
(varies by model)
Modem
56K ITU V.92 PPT approved, Wake-on-Ring ready
Ethernet
Acer InviLink™ Nplify™ 802.11b/g/Draft-N Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology, or
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Bluetooth® 2.0+EDR (Enhanced Data Rate).
Gigabit Ethernet, Wake-on-LAN ready.
(varies by model)
Dimensions / Weight
15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack.
AC Power
100-240V AC AutoSensing Adapt
what model
