Cell Phones Logo
Posted on May 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am installing a mobile car antenna to the rear window of my vs commodore car and it has on the inside of the window a decal style sunshade across the full length of the top of the window.the decal is black in colour so the problem there is that I can't see through it to line up the outer part of the antenna to the inside part and the decal being made of plastic, is it ok to stick the inside part of the antenna to it and if its ok to do so any suggestion on how to aline the both together?
deton8 von Splosion
Level 3:
  • Acer Master 3,342 Answers
  • Posted on May 28, 2017
deton8 von Splosion
Acer Master
Level 3:
Answers
3342
Questions
6
Helped
928771
Points
54123
The question about OK to stick on the "inside"...
You need to identify the composition of the
"DECAL" and the compatibility of the ADHESIVE
because worse than not COMPATIBLE reactions
can RUIN both elements... leaving you with
an ugly mess....
SOME ADHESIVES SIMPLY DO NOT LIKE PLASTIC.
Otherwise if the DECAL is non-metallic you should
be fine... High frequency radio is quite excellent in
direct close quarters (nothing to worry about there)...!!
Use masking tape to attain PERFECT SYMITRY on
the outside... Extend a piece into the clear area and cross
it at a easily accessible spot... OFF-SET Measure it on the
OUTSIDE... and measure it precisely back on the INSIDE.
(Personally... I think that vehicular communications has
been the finest safety advancement since safety restraints
(safety belts & air-bags)).
Happy motoring!!
Carnac the Magnificent
Holden VF Commodore. Will a VE radiator support panel fit a VF Commodore?
Unlikely
The VF Commodore was built on an altered version of the Holden designed GM Zeta platform, first used in the VE Commodore. The VF was an evolution of the VE, with several visual changes. The VF featured new styling at the front and rear, with a more modern, sculpted appearance replacing the VE's simpler design.
Holden Commodore (VF) - Wikipedia
https://en.wikipedia.org > wiki > Holden_Commodore_(VF)
History of the Holden Commodore part four: VE-VF models
https://www.whichcar.com.au > features > history-of-th...
May 31, 2018 - It was no secret that after six years, the VE's interior was looking aged, with criticisms around quality on the otherwise well-loved model ...
2answers
How to install starter motor for VS commodore
I suggest you pose the question on the VS section of the Just Commodores Forum and one of the guys there should be able to help you with that.
Here is the link to the website........................
Forum VR VS Holden Commodore 1993 1997
2answers
How to install replacement sunroof motor on a 1999 Pontiac grand prix
Important: This sunroof system is timed from the factory in order to allow the actuator to shut off automatically when the sunroof window reaches a certain position. Use extreme care when removing the actuator from the sunroof module. This may cause the timing to be thrown off. This may damage to the sunroof. Anytime the actuator needs to be removed from the module, ensure that the sunroof window is in the fully closed position.
Remove the sunroof window. Refer to Sunroof Glass Panel Replacement .
Slide the sunshade fully rearward. Move the sunroof window to the vent position. Remove the sunroof screws (two on each side). Remove the sunroof window from the module.
Place the sunroof module in the fully closed position. Remove the headliner. Refer to Headlining Trim Panel Replacement in Interior trim.
Tools Required ?€¢
J 38778 Door Trim Pad and Garnish Clip Remover
J 2772-C Headliner Installer
  1. Remove the sunshades. Refer to Sunshade Replacement .
  2. Remove the overhead console, if equipped. Refer to Roof Console Replacement .
  3. Remove the sunshade retainers. Refer to Sunshade Anchor Replacement .
  4. Remove the power sunroof switch, if equipped. Refer to Sunroof Switch Replacement in Roof.
  5. Remove the sunroof trim lace, if equipped. Refer to Sunroof Seal/Molding Replacement in Roof.
  6. Remove the dome light, if equipped.
  7. Remove the coat hooks. Refer to Coat Hook Replacement .
  8. Remove the assist handles. Assist Strap Replacement
  9. Remove the rail lamp. Refer to Roof Side Rail Lamp Replacement in Lighting.
  10. Remove the windshield side garnish molding. Refer to Windshield Pillar Garnish Molding Replacement .
  11. Remove the upper quarter trim panels. Refer to Rear Quarter Upper Trim Panel Replacement .
  12. Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement .
  13. Pull down on the door opening weatherstrip seal on both the front and the rear doors.
  14. Remove the 2 rear retainers (2) using J 38778 Door Trim Pad and Garnish Clip Remover. Disconnect the headliner electric harness at the right side of the rear window shelf. Rotate the right front seatback to a horizontal position. Remove the headliner from the vehicle through the right front door.
Disconnect the electrical connector from the actuator.
Important: Before removing the actuator, ensure that the pins J 41718 are tight and holding the cable.
Thread the J 41718 into the front sunroof window screw hole in order to retain the cable adjustment. Remove the sunroof actuator screws. Remove the sunroof actuator from the module. Did you look for a video on youtube ?
Hi I have poor reception in my car. Not sure exactly where the booster or being a calais where abouts is the second antenna? I heard that they had a built in one in the rear window. Is that true?
They came standard from the factory with an electric ariel, The ariel was located in the LHS Fr quarter panel just in front of the passenger rear vision mirror on the door. not sure if they had the adjustable electric ariel which would have an up and down arrow button just on the deck or under wear the factory head units were installed. The biggest problem for reception is if they are not earthed properly against the car. if the antenna has been replaced theres a good chance someone may have stuffed up the installation. its best to take the front left tyre off and remove the inner wheel guard/surround so you can get to the ariel unit. from there the cable just runs through the firewall panel and behind the dash to the stereo. they are easy to pull through but make sure you know which holes they came through. when pulling new cable you should remove the glove box to. just pull one of the back corners to the center and it will pop out then the rest is easy.
To simplify things you could just install a manual ariel aswell (430) new electric ones may cost around $100 for a aftermarket one.
1helpful
2answers
Vs ecotec vs commodore engine light comes on after driving
I have no dash lights so at night I can only use the speed set to let me know what speed im doing how do I fix them in 95 vs commodore
1helpful
Radiater fluid coming from behaind balancer Model V6 VS Commodore New Radiater instaled and not coming from there any Ideas???
check your entire cooling system for leaks including water pump, thermostat, radiator hoses, even your coolant reservoir. leaks are rough man sorry for your frustration.
4helpful
My antenna broke, i purchased new antenna but when I tried to install new antenna the old antenna fell inside of radiio, I took out all the screws but still cannot get radio apart
On the back panel, there is a black decal located near the center. Warm this decal with a hair dryer (warm it, don't get it hot)Slip a knife blade under the right side and lift it up. Remove the hidden screw under the decal, and the the other five and the back will come off. replace the FM antenna and you are good to go. I had the same problem. mcarmich
I have to replace the power window motor on my BMW x5. I cant get the door panel off becasue of the built in window shades. any help?
Hi Racegas, I am assuming you need to take off one of the rear door panels. The 1/4 glass sunshade needs to be removed to gain access to a hidden screw.If you are looking at the sunshade from inside of the car. Lower the window, and look at the op of the shade assembly on the inside. You will see a square looking hole. Using a small pocket screw driver, or equivalent, insert the screwdriver into the hole and pry upwards. Pull the assembly to you at the same time. The clip that holds the assembly in place is pretty stout. You may want to shine a flashlight inside the hole to get a better idea of how far to pry the retaining clip up. Just in case you need to know, there are 2 screws under the trim strip that is adjacent to the release handle and one toward the bottem of the door near the interior pocket.
67helpful
7answers
Vt Holden Commodore stereo wiring diagram
Here are the wiring codes for the VT,
VN-VT Commodores:
Accessory (12V) Yellow
Battery (12V) Orange/White
Ground (earth) Black/White
Antenna power (12V) Yellow/Red
Front Left + Tan
Front Left - Grey
Front Right + Light Green
Front Right - Dark Green
Rear Left + Brown/Black
Rear Left - Yellow/Blue
Rear Right + Blue/Orange
Rear Right - Blue/Black
Antenna Up White (VR-VT)
Antenna Down Blue (VR-VT)
Phone Mute Yellow/Black (VT)
Dimmer In (12V) Brown/White
Dimmer Out (12V) Grey (VT)
Top Acer Cell Phones Experts
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Acer Cell Phone Expert? Answer questions, earn points and help others
