Maytag Neptune FAV6800AW Top Load Washer Logo
Anonymous Posted on Apr 11, 2010
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
  • Anonymous Apr 12, 2010
    I have FAV6800A. Serial number begins with 11.
  • Anonymous May 11, 2010
    Can you let me know which model do you have, FAV6800A or FAV9800A? The first two digits of you machine serial number it will be 10 thru 17.
Anonymous
Level 3:
  • Master 526 Answers
  • Posted on Apr 12, 2010
Anonymous
Master
Level 3:
Answers
526
Questions
0
Helped
142986
Points
1214
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Anonymous
Level 2:
New Friend:
  • Expert 79 Answers
  • Posted on Apr 11, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
79
Questions
0
Helped
20404
Points
130
Try jump out lid swt .two wire pump together
Maytag Bravos washer starts cycle and fills, but at noise at agitation/spin then starts and fails immediately
i reccomend you check the drive belt if its worn, damaged, or misaligned. motor bearings that are damaged can result to result in grinding noise
The motor is running but it won't turn the belt on my front loader ge washer
It definitely sounds like the belt is stretched, worn-out, and in need of replacement.
I have a lgwm 2677hbm washer and got a code read out de .i looked it up and it said drain error,i cleaned the drain filter but it sounds very loud during the rinceand spin cycle and i dont know if this...
It is not likely an object got past the filter before the pump, so I'd guess that the impeller has come loose from the pump motor shaft. Replace the pump motor. (washer will not spin if water is still in drum)
33helpful
2answers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
2answers
Pump won't stop
ur controler most probabley gone
1helpful
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
