Some potential steps for restoring a missing toolbar in The Print Shop 23 include:
Consult the user manual or online documentation for The Print Shop 23 to find instructions on how to restore missing toolbars.
Use the program's settings or options menu to access the toolbar settings.
Select the page turner toolbar from the available options and enable it.
Save the changes and exit the settings menu.
If you are unable to restore the page turner toolbar using these steps, you may want to consult the user manual or contact the manufacturer for assistance.
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive. Let me know if this solution helps.
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
Print Shop version 21 Deluxe is not compatible with Windows 7. You have to use a newer version 23 which is compatible. This is due to software compatibility with Windows 7.
You can check forcompatibilites issues @ Windows 7 "software & hardware" compatibility center
Print shop deluxe version 20 is not designed to work on windows vista. it was designed to work on windows 98 up to windows xp only. Try using a version that is compatible with vista like version 23.
you have to go to the help section or help tab at the top of your printshop window, on your printshop program...and then click technical support , and it will give you options...click on the option of troubleshooting and it will take you to the broderbund direct online troubleshooting page, and click on the appropriate option for windows vista 64bit, and it will walk you through step by step; which involves going into your printer port settings under control panel section of your computer, and just follow the online directions...I just did it and my newsletter on printshop 23 deluxe is now saving without problems!
