Harman Kardon AVR 635 Receiver Logo
Posted on Apr 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AVR 630 powers up and 5 sec after that powers itself off
It never happend before. I changed electric outlets and the problem didn't go away. Any idea how to fix it? Big thanks.
Dennis McCollum
Level 2:
  • Expert 137 Answers
  • Posted on Apr 14, 2010
Dennis McCollum
Expert
Level 2:
Answers
137
Questions
Helped
90098
Points
291
This unit has shorted output transistors causing unit to go into protect mode.
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
When I power my Denon AVR-3311ci on, it only comes on for a second then shuts off completely. No blinking red light and nothing on the display. I can hear a relay on the power board clicking. Any ideas?...
There's an electrical problem! The unit shuts off to protect itself. the relay sound is normal and is part of the power supply - good quality amps have them. I suggest taking it to your local repair shop.
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
3helpful
Denon avr-1804 its turns back after 5 sec
Disconnect all speaker wires on back and then turn on. If it happens again, it's most likely a power supply problem. If it doesn't happen again, it was probably crossed speaker wires.
Hi, i am having problems with the multiroom on my AVR 630
Go into your OSD (on screed display).
Go to multiroom.
Change the SB AMPS from MAIN to MULTI.
Make sure you have only analogue sources, it will not amplify digital inputs for the MR.
Electrical noise
You have a loose ground on the outlet. check it out................
One other thing, you have bought the worst, cheapest design and the least protective product in the world without AVR technology.
I am a power quality engineer and I loath APC quality.
www.storminproteciton.com
check out some real UPS that might do better.
Powers on 5 sec then powers off
if it goes off even with no sound, system is put on stndby protection mode. something wrong with your output section. busted power output xtors of IC.
3helpful
2answers
Flashing protector
Psgolfer ...I pretty shure you dont need that. It just needs to be reset, its in protect mode.....hold the power button down and the A n B speaker buttons down at the same time for 30 sec.....ok , Radricktip
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
