Replace the door switch, but,..... if you order the switch, they may send the switch in a rather large and heavy (and somewhat expensive) box which also contains the lower counter balance for the front of the drum. The reason is that on some machines, the counter balance is shapped in such a way that on certain off balance loads, the counter balance is able to strike the door switch and break it. The new counter balance weight has been re-designed to prevent this from occuring.
SOURCE: Washing Machine LG WD-8013F
it may be the lock but this model is known for board faults,take of the top panel and remove the control panel and see if the board is burnt.there was a recall on some of these machines a while ago in australia not sure where you live
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
SOURCE: door will not open on hotpoint wd420 washing
Turn off the power and isolate the water supply, Move the machine in to the middle of a room - you need some space. If you then rock the washing machine backwards, there is a door release. It's extremely hard to reach, about level with the lock, so make sure the machine is both stable and that someone is with you to ensure the machine doesn't fall and crush you to death!
It basically looks like an little electronic panel, in the middle of which you can see a steel knoble. Press with some force, and the catch will release.
This just happened to ours, and the actual lock is broken, so that was why we couldn't open the door. Yours might have a similar fault. The mechanism is partially plastic and it looks like the plastic sheared off and then the electric release no longer pulls the catch in to the position where it will release.
