Drive Medical Drive Phoenix 4 wheel scooter *Free Batteries/Free Home Delivery! Logo
Posted on Apr 10, 2010
When i turn my scooter on the ready to use indicator light just flashes. i have checked all of the electrical connections and the fuses but they're all fine. what am i overlooking?
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Apr 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
9567
Points
34
You have the brake off
call 0208 676 0944
Lights will not turn off and after turning on scooter in a few minutes, hear a beeping
If the lights on your Golden 3-wheel scooter won't turn off and you hear a beeping sound after turning it on, it could indicate a potential issue. Here are some troubleshooting steps you can try:
  1. Check the key switch: Ensure that the key is inserted fully into the key switch and turned to the correct position. Sometimes, if the key is not fully engaged or turned properly, it can cause electrical issues. Try removing the key, reinserting it, and turning it to the correct position.
  2. Examine the battery connections: Inspect the battery connections to ensure they are secure and free from corrosion. Loose or corroded connections can affect the scooter's electrical system. If you notice any loose or corroded connections, carefully tighten or clean them as needed.
  3. Verify the charger connection: If the scooter is connected to a charger, make sure it is properly plugged in and connected to the scooter. A loose or faulty charger connection can cause electrical malfunctions. Try unplugging and reconnecting the charger to ensure a secure connection.
  4. Check the scooter's manual: Refer to the owner's manual or user guide for your specific model of Golden 3-wheel scooter. It may provide troubleshooting steps or information about the beeping sound and lights issue you are experiencing. Look for any error codes or indications that can help diagnose the issue
When i turn the key on the scooter, nothing happens and nothing lights up, i have checked connection and all show power, the power indicator does not move, yet batterys are fully charged any ideas TIA
hi Shane, i recommend you check the fuses on the tiller ..
if all okay check the fuses located on the battery leads , if fitted and check the connections to the controller which is located under the foot panel..
Regards
Rob
Rascal Candy Apple. Why did it stop moving while I was driving it?
On the rascal, if your driving along and it suddenly stops, the throttle lever could be bad or the speed control could be bad or both. A battery lead maybe loose. The tiller cable may have slid back causing line interruption.
The flashing 4 indicates current timeout, the scooter may have been going up a steep hill, over heating the motor, turn off and allow motor to cool. then try again. if this happens on flat ground then check the parking brake, it maybe hanging up causing the motor to over work. Other trouble-shooting information for rascal, scooters on my free app.
Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
How do l fix the brakes for CTM HS 250 Mobility Scooter?
hi, the error is covers a number of issues however the brake is one of them.
Now check the wiring of the brake from the controller, if you have a electrical meter disconnect the brake and take a reading, it should read about 35 to 50 ohms on your meter set on lowest resistance reading.
Now if the reading is out this range , this could well be the problem,
If it's not check the connection to the controller.If there is a microswitch fitted check that making a connection.
Regards
Please rate my feedback..
1helpful
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
1helpful
Wrench lite comes on and scooter will not move. I have checked the electric hook ups, all OK. I wiggled the control stick and it move for just a few feet. What could it be?
The wrench light indicates a problem count the number of flashes ie 4 flashes pause 4 flashes indicate a motor problem See my tips on flash codes. Once you get the flash code then you will have to get the chair repaired because there is no self fix for those errors Hope this helps
2answers
Scooter just stopped moving .new battery. tryed reset button
Did you replace both batteries at the same time? has the scooter been sitting idle for a while? Are the lights on the controller flashing or steady? If no lights come on at all, you may have blown a fuse. If the lights are flashing, this link may help you to diagnose what the problem may be related to: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Top Drive Medical Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
