Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
Posted on Apr 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil and gas mixture
What is the correct oil/gas mixture for Ryobi 31cc 700r 15"
Bob Korsu
Level 3:
Guru:
  • Master 1,051 Answers
  • Posted on Apr 11, 2010
Bob Korsu
Master
Level 3:
Guru:
Answers
1051
Questions
0
Helped
403228
Points
3047
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1046
Points
I have the exact model and the ratio is 32:1 (sticker on housing).
Anonymous
Level 1:
New Friend:
  • Posted on Aug 05, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1046
Points
My ryobi 700r mixture is 32.1 on the label
4helpful
My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
5helpful
Bought new e3 plugs for weedeaters and cant find gaps for them i have a Featherlite 20cc Fl20 and a Ryobi 31cc 700R
The gap for the Weed Eater 20cc engine can be set @ .025". The larger engine Ryobi 31cc/32cc class can be set @ .030" Either engine would operate within that .005" range and I know a 32cc Poulan calls for a .030" gap.
Jul 09, 2010 • Garden
1helpful
What is the correct oil/gas mixture for Ryobi 31cc 15"
I'm pretty sure it's 50:1 but checked with your local dealer to be sure.
2helpful
I need to know how to load a two string trimmer head. This is on a ryobi weedeater model 700r, 31cc, 15 inch.
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
Aug 25, 2009 • Garden
5helpful
What is the ratio of gas and oil mix for a ryobi 31cc trimmer
just use about 3 to 4 ounces of 2 cycle oil per gallon and you should be fine. a little extra lubrication wont hurt it
3helpful
Gas oil mixture
Hello slabieniec:
The Newer 2 Cycle Trimmers use a 50:1 Ratio (OEM Suggested Ratio). I Use a 40:1 Ratio in Most of my Equipment, Except for Chainsaws and Hole Drillers/Augers. For the Chainsaws I Use a 32:1 Ratio and the Hole Digger/Auger Uses a 25:1 Ratio.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
6helpful
My ryobi 31cc 15" 700r won't start
You need to push the primer button 10 times or so (the button at the top of the speed control) to get the gass pumped up into the system again. Likely gas not getting through the line yet. Takes awhile.
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
