Coad F21 keeps flashing
you have to clean out the pump.unplug the washer,open the door and with a shop vac vac out the water from the tub.next remove the bottom panel and you'll see the pump,in the middle of the pump you can remove the middle piece,have the shop vac ready,turn the middle piece counter clockwise slowly until water starts coming out,vac it up until it drains out,then remove the middle piece of the pump,most likely you'll find coins and a bunch of other gross stuff,also it could be stinky,clean out the coin catch and then stick your finger in the pump and feel around,make sure nothing is stuck where the impellar is,also check the rubber hose behind the pump,sometimes things get stuck in there,i stick the vac in the pump and vac out anything that's in there. put the piece back in the pump,plug in the washer,next dump some water into the washer with a container like a half gallon or so,put the washer on drain and see if it drains,if it doesn't drain turn the middle piece of the pump and drain out the water and check to see if anything is stuck in the impeelar of the pump,if it's clear the pump is bad but most of the time the pumps hold out.let me know how you make out and one more thing the number one killer of front loaders is to much detergent,if you use the cap off the bottle you should be using 1/4 a cup that's it,it's h.e. detergent and it's double the strenth of regular detergent.it eats at the rear bearing and spider gear,when it breaks the machine makes a loud banging sound in the spin cycle and it's time for a new washer,the part alone is 500 dollars so cut back on the detergent
