Need to pull generator armature off to rebuild engine for son at school in small engine class teacher never did it before
Put the armature thru bolt in and back off about two turns. Smack the thru bolt hard with a hammer and the armature will release from the tapered crankshaft. You may damage the thru bolt. If so either get a new one or use a piece of all thread and a nut.
THIS WORKED PERFECTLY ARMATURE IS OFF THE SHAFT THANKS
