Coby MP550  MP3 Player Logo
Posted on Apr 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drivers for Coby MP3 player model no MP550-2G. I have windows XP
YourZEN
Level 3:
  • Master 820 Answers
  • Posted on Apr 10, 2010
YourZEN
Master
Level 3:
Answers
820
Questions
0
Helped
370948
Points
2866
Having Operating System Windows XP, most mp3 players can be recognized in Windows Media Player 11 software from Microsoft.
How to use WMP11 look on next site:
http://www.microsoft.com/windows/windowsmedia/player/11/using.mspx
You can also use Coby Media Manager from the manufacturer for media transfers. See next page for how to download and install Coby Media Manager, for XP download the execute file coby-mediamanager-2009b0924.exe on next site:
http://www.cobyusa.com/?p=fix_mp822
After download and installation, run Coby Media Manager:
select Tools > Device Manager...: select MP-550 from the list:
click Add : click OK to have the MP-550 as your operating device.
Under Device Configuration you can set the synchronizing location and
bitrate conversion for audio.
Need more help ? Just add a comment.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2121
Points
Mi coby mp3 no prende y no puede escochar musica que hago
2 Related Answers
Anonymous
  • Posted on Nov 15, 2008
SOURCE: ''Freeware'' COBY software to download pic's, video and music
To upload file to the COBY MP3 player, I went to setting, went to USB setting's, changed MTP mode to MSC mode then I was able to get access to folders with-in the mp3 player.
The_Tonester
Andy
  • 64 Answers
  • Posted on May 29, 2009
SOURCE: Windows XP Pro will not recognize Coby MP3 player.
could be one of two possibilities. one something is wrong the usb wire or two, the player is locked. mine did the same thing when i first got it. i unlocked it and it worked
2answers
Computer (Windows XP) does not recognize the Coby MP-C7085 player
On the MP3 player, go to settings > system, put the USB mode to MSC, then reconnect to the computer, computer will read, the device is currently on MTP and your computer doesnt have driver so that is why its not recognizing.
1helpful
When I plug in my mp3, i cant sync because wmp doesnt recognize the mp3 at all. I was trying to find software or driver download to help fix. please help!
Hi, Looking for Drivers.
In order to download the right driver for a Coby MP3 player, you'll need to go to the Coby website support page where you can download software drivers (See Resources). To find the driver you need, you first need to identify which device you're using. Select "MP3 & Portable" under where it says "Select a Product" on the first box on the left. In the second box, it will be "MP3 & MP4 players." The final box lists all of the MP3 and MP4 players that Coby produces. You'll need to find your MP3 player in this list. The designation will be letters and number such as "Mp200". It should be listed on the box. Once your MP3 player is selected, clicking on the "Submit" button at the bottom will cause the text "Available Downloads for Mp200" (or whatever your MP3 player is called) to appear towards the bottom of the screen. Underneath, there should be a link for "Driver," if there is one available for your player. Clicking on that will allow you to download it.
Installation
If you click "OK" on the download screen, your driver should install. It will likely be in a ".zip" format, which means another program is needed to "unzip" the file so that you can install it. An example of such a program is WinRAR (See Resources). This program needs to be installed first, before it can be used to unzip your driver file. After you've downloaded the program, opening the installation file will begin the installation process. Choose a directory for where the program will be installed. After installation is complete, you can go back to the ".zip" driver file. Double-clicking on the file will bring up a new window. You can now drag your driver files from inside the .zip folder to any folder on your computer that you wish. There will be a file marked "Setup" among the unzipped folders. Opening this file should allow you to install the drivers you need on your computer.
Also Coby mp3 player not recognized by the computer.
Why is my Coby player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Coby mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Coby mp3 player can connect to your computer in MSC or MTP mode. Exceptions are Coby mp3 player Connect and Coby mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for Coby Players when used with Windows OS.
The Coby player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope that helped..
I need the driver for it
See this tip posted here on this site - copy this address into a new window - -> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-
Media player 11 doesn't recgonize coby mp3 player
Thanks for the tip on Colby mp3 I won't buy that either. The RCA mp3 isn't much better.
Coby MP-C827 MP3 Player
Windows XP is plug and play, so it doesnt require any drivers on Coby's end. You need to do Windows Update to update your drive package, it seems you are missing the USB MASS STORAGE device driver.
Cant detect it
Me too. I think it is a manufacturing defect, as I've tried it on several PCs and they all have no problem with other Coby mp3 players.
2answers
Coby mp3 drivers not found for model mp-c683
Unless you are using Windows 98, you will not need one. Plug and play - the player is so old Coby doesn't really support it anymore. If you're experiencing a specific problem, post it here. If you're using Mac or Linux or Vista - forget about it - this player will not work on those systems.
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
