Sewing Machines Logo
Posted on Mar 18, 2008
Pfaff 7570 Sewing Slow
It forms a perfect straight stitch but slows very slow. When I change stitches it still sews a straight stitch very slow. It may move to a different needle position but doesn't form the selected stitch. It was serviced last week and was sewing fine. The first sign of trouble was that it started sewing backward without the reverse selected. Now this!!
  • Anonymous Mar 20, 2014
    Stitch knob is frozen
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on May 04, 2008
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
8031
Points
24
Unfortunately, this is most likely a computer board issue and there's just no way to predict if/when a board will go bad.
Your only option at this point is to take it to an authorized Pfaff dealer. If the person who serviced it was an authorized Pfaff tech, take it back to them. If not, do take it to a Pfaff dealer - non-Pfaff authorized techs are not trained on the machines.
Sorry I can't give you a simpler answer, but until this is corrected, your machine won't work properly.
Best,
Kim
2answers
Is an Elna 2006 sewing machine capable of free motion quilting. The feed dog doesn't lower but I read you can use the darning plate to cover the feed dog- What should I set my stitch length at?
Can I Free Motion Quilt on a Regular Sewing Machine? By National Quilters Circle
Yes
https://www.nationalquilterscircle.com/article/can-i-free-motion-quilt-on-a-regular-sewing-machine/
How to Stitch the Perfect Stitch Length for Quilting
JULY 28, 2020
Today’s Topic: How to Stitch the Perfect Stitch Length for Quilting
https://lorikennedyquilts.com/how-to-stitch-the-perfect-stitch-length-for-quilting/
Hi I have a pfaff 7570 which sews very slowly and does straight stitch only even when the setting is for fancy stitching. Can anybody out there help me? Thanks
The very first thing to do is
Make sure all of your cables are FIRMLY attached and that the foot control is connected.
Make sure the bobbin winder is in the sewing position (see Manual for details of this).
1helpful
Have Pfaff 7570. Can I sew 4 holed button?
If it is a flat button that will fit under the presser foot, of course you can stitch it down with your sewing machine. (I like to use gluestick from the school supply bin to stick the button to the fabric.) Be sure to deactivate the feed dogs while you are sewing on buttons.
You'll just need to stitch two button holes and then rotate the fabric & button and stitch the other two holes.
How to Sew on Buttons With Your Sewing Machine Sew4Home
My 7510 says "adjusting pattern" 248 when I turn
I had this problem a few weeks ago. A new baseplate fixed it. You will need to take it to a Pfaff repair shop
2answers
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
7570 Pfaff - stitch length
Make sure you raised the feed dogs.
Probably a bad circuit board. It needs to visit a Pfaff dealer for diagnosis and repair.
sewman7
HARD DRIVE 7570
Ask this tech kimbo322
An ex- PfaFF employee
Post your question to that tech
Top PfaFF Sewing Machines Experts
ExpressFiX
ExpressFiX
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
