Question about Mustek PVR-H140 Digital Media Player
My mustek pvr-h140 will power on and start to initialize
My mustek will power on and start to initialize and then shut down I do not know what is wrong.
SOURCE:
  • 22 Answers
SOURCE: NEED DRIVERS FOR MUSTEK PVR-H140
HI,
the drivers for the unit are available at http://www.nodevice.com/driver/_PVR-H140/get33981.html
you can use the unit as an external drive, you will need to connect the it to your computer via usb then power it up, after 30 seconds or so it should show up on "My Computer" as an extra drive.
if it doesn't show then the internal battery could be flat, though it will charge via the usb if the power is off (red light on when charging) or use the supplied power adapter.
G.
Posted on Jan 14, 2009
  • 4 Answers
SOURCE: HOW TO CHANGE THE MUSTEK PVR-H140 BETTERY
It is real easy to change the battery, I have done mine a few months ago
if you remove the screws from the back top and bottom (4) and remove the case
next remove the 2 small rubber strips from each side of the hard drive, then very carefully pull the connecting ribbon off the hard drive, this can be tight so gently prise apart with a screw driver,
once the hard drive is removed you will see some earthing straps just make a note of where these are located as you will need to put them back in the right place, they simply touch the hard drive,
now you shoud see the battery (very thin in a blue plastic case) you might want to remove the rubber proctective stuff just to make it a bit easier there is a simple pull/push connector
just unplug it and replace with new battery and reverse the procedure.
Dont panic if the unit fails to switch back on as mine did when i re assembled it
it was just one of those earth straps in the wrong place.
I hope this helps,
P.S I changed the battery on a unit I bought on ebay and i had nothing to loose
if you are unsure do not attemp the repair.
Posted on Jan 17, 2009
  • 4 Answers
SOURCE: just bought the mustek pvr-h140 without manual. No instructions!
I have the instructions on pdf if you can send me an email address i will forward on
Kind regards
Kev
hunter19_46m
  • 7482 Answers
SOURCE: How do I get a user manual guide for a Mustek
You can download at this site.
http://www.driverstock.com/Mustek-PVR-H140-driver-download/31-34-9027-69650/index.html
Good Luck,
I hope this helps
Posted on Nov 11, 2009
the_pete
SOURCE: AC power jack came loose from the board
This happened to me too. Just unscrew the 4 screws, lift out the hard drive and glue it back down to where it was (2 little pegs will fit into two little holes on the circuit board. You can touch the contacts with a thin tipped soldering iron if you want to but you probably don't need to.Then close it up. That worked for me!
Posted on Jan 03, 2010
AC power jack came loose from the board on both the Yukai PVR-H240 and Mustek PVR-H140. Is this a common problem?
Aug 23, 2009 | Mustek PVR-H140 Digital Media Player
MUSTEK PVR-H140 died on me
You may already know this, but tap the power button once more and it may turn on the screen.
Jan 31, 2009 | Mustek PVR-H140 Digital Media Player
Mustek PVR-H140 shuts down when I insert some SD cards
Yes that's correct newer SD Cards use faster memory chips that are not always compatable, not just with this unit but you can have the same problem with cameras and other MP3 players as well.
The PVR-H140 is quite old now so stick to the older type cards, oh and they dont like being hot swapped, this can cause a shutdown or driver corruption, insert them before turning the unit on.
Jul 26, 2008 | Mustek PVR-H140 Digital Media Player
HI,
G.
Jul 12, 2008 | Mustek PVR-H140 Digital Media Player
HAVE A PROBLEM TRYING TO START MY MUSTEK PVR-H140
i think that you will need to send it back to the mustek shop, the same thing happened to me, and they fixed it for me, within a week
Apr 16, 2008 | Mustek PVR-H140 Digital Media Player
Frozen in "Initalize"
you need to go to musteks website and download the following file pvr-h140_restore_files.zip from product support area
that should get your pvr working again ?.
link to support page
http://www.mustek.com/mustek/supportdrivers.php
Apr 08, 2008 | Mustek PVR-H140 Digital Media Player
PVR-H140 doesn't work but cannot restore files
Problem is once the hard drive is corrupted you can't access usb to fix the problem. You have to remove the four screws on the back cover remove the 40gig hard drive. Find a laptop or an ide to usb adapter to reformat the drive. Must be fat32 not ntsf. Then copy all files back onto drive.
Nov 10, 2007 | Mustek PVR-H140 Digital Media Player
PVR H140 - Frozen on "initialize" screen. I've been looking for help for awhile.
Hi, If you haven't solved this problem, I would be interested in buying the Mustek for spares - let me know. d_ponsford@hotmail.com
Aug 10, 2007 | Mustek PVR-H140 Digital Media Player
Mustek PVR-H140 Digital Media Player Logo
280 people viewed this question
Top Mustek Audio Players & Recorders Experts
John Elliott
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
