Steve, The 1st thing is to install the correct driver for the 100 on the computer you are using. Is it a Mac or PC? What model of computer is it. I have been able to use the Zip100 disks with an older IIGS and some older Macs (Performa and Mac SE) with no problems. I have had no experience with the PCs. The disks formatted as FAT16 or FAT32 can be read by both Mac and PC. Those formatted for the PC can also be read by Macs if PC Exchange is installed. Mac disks cannot be read by a PC.
Write back with more info to clarify your exact situation.
Ron
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
Its probably a bad disk. The only way I have been able to fix these is to First launch disk utility THEN put the disk in. THEN run the utility. You have to do it in this order. The key thing here is utility has to be running first and then insert the disk "HOT"
Hope this helps!
right click my computer.
click manage
selest disk management
right click to drive-H
select change path 7 name of drive
change it to any letter except lettur used for your other drives
thats it it is done.
Your SCSI card sounds like it is either loose or knackered, look inside your machine and make sure all connections are connected as you would expect on the SCSI card and any cables, if all seems ok then beg borrow or lend another SCSI card from a friend or another machine try that if all is ok with the other card then your problem is sorted, knackered SCSI card.
