Make sure your remote is working with fresh batteries. There is no history of how long you have had the TV etc. Use the manual power button if the remote wont work.
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug. If you are lucky it maybe just a fuse blown out. Thanks
Hi, Here is a link to the codes, but I suspect you already have them and your devices aren't listed.... http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
So, you can manually code your jumbo as follows;
Turn on the device you wish to match with your remote. Aim the remote
at the device and press and hold the Code Search button in the upper
left of your remote for at least 3 seconds until the LED light on the
remote turns a solid red. Press the button on the remote for the item
you want to program (TV, DVD, etc.). The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program
turns off. The LED light will blink once each time you depress the
On/Off button. When the device you want to program turns off, press the
ENTER button. The LED button will turn off and the code for that device
will be stored in your remote.
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it
on.
Solution: I just had one of these come in. I opened it up, and found
the U501 capacitor a little suspicious looking, in that it had a
deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I
replaced it with a very good quality 1000uF 16V electrolytic 105degC
10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to
turn it on, the LED was yellow for a second, then green, then I got a
picture, and it appeared to work great. I then asked the owner a week
later how it was working, and they said it was working just like new!
