Make sure the stop motion wheel is tight, if it will not tighten you will need to undo the stop motion wheel, undo the screw that is in the stop motion wheel, unscrew the stop motion wheel all the way off and you will see a three pronged washer, take the washer off and put it in a different position, put the stop motion wheel back on and tighten to finger tight, screw the screw back up in the stop motion wheel, a final turn one the the stop motion wheel to tighten then test, if it does not work put the three pronged washer in a different position even upside dowm.
