I am an electrician about to connect a 2 part oven to an existing 32 amp cooker point, although each part is supplied with a 2.5sq mm flexible cable the actual current rating of each part is in excess of 13 amps. The installation manual suggest each unit be either connected to a respective socket outlet or by direct connection through individual double pole isolators. Can you suggest how this be best achieved using the existing 32A cooker point. I cannot connect both these flexes to the existing point since to do so means each individual flex is not adequately protected in accordance with BS7671 Regulation 433-02-01. The only socket that could be used is either the old 15A round pin or a 16A type to IEC309 but the latter is precluded in domestic installations since it is not fitted with safety shutters as required by BS7671 Regulation 553-01-04 and in any case these would have to be protected in accordance with their current rating.
SOURCE: 4200 speedstream modem problem
I guess you probably aint set-up a wireless router before, what you need to do is get it connected up so you revieve local area is connected then, load internet explorer you will recieve a message like page not displayed. where you usually type in www.ebay.com for example type in the number thats on the bottom of the router ie it looks somthing like this 192.168.1.1 for example. a menu will then appear, fill in your broadband username details etc and you should be up and going, if you have problems feel free to email me,, All the best John [email protected]
SOURCE: Internet connection
I think your modem needs to be configure by your ISP.
I change my modem here in my house with other brand and did'nt work, so i put the original modem i used and it works again..
SOURCE: Speedstream 4200 setup
I have just set up 4200 with dsl - you may find that you need to reset modem before you can configure. I was told that you need either a grey or yellow cable from your laptop to the modem. I use 10.0.0.138 to access modem. The 4200 I have was from a bigpond a/c - originally configured accordingly.
Regards,
Richard
SOURCE: siemens ADSL Modem(model- C2110)
u need the driver when u r using usb cable. if u r using ethernet cable u dont need the driver when u will turn the modem on u will automatically connect to the internet..
or if u want to configure ur modem type the ip address 192.168.1.2 in ur browser and u can then cofigure this by ur own
SOURCE: unable to set up internet connection - option greyed out
in order to connect to internet you require a username and password
that user name and password will be given to you durin first time installation if you dont remember the username and password call up your broad band help desk. they will help with the user name and password.
if you are aware of the user name and password ,
you need the configure the internet setup using the user name and password
i ll give the steps to configure the user name and password in windows XP operating system
1 click on "start" button at bottom left of your desktop
2 click on control panel
3 on left hand side of the window click "classical view"
4 then click on the icon network connections
5 there you will find "create new connection" or "new connection wizard"on the left hand side just double click on it
6 a new dialog ll appear click next
7 on the next screen select "connect to internet" and click on next
8 on the next screen click on "setup my connection manually" then click on next
9 on the next screen select the option "connect using a user name and password" and click next
10 you will be asked for ISP name "for eg:fill in AT&T"
11 on the next screen you willlbe asked for user name and password , fill in the respective details
for eg: sam @att.net :username
******** :password
12 den click finish
you will find an icon in the desk top by now. just double click on that icon and try browsinn
you must be up and runnin ! ! !
