It's not that unusual for a battery to fail that soon, and the "no lights, no nothing" says that it's the battery again. Your best bet at this point is to pull the battery and take it to the point of purchase for testing. They should either replace it under warranty or charge it for you. After you replace the battery you should have the charging/electrical system checked for possible shorts or power drains. BillB
Check Battery in car(make sure is not weak or dying), check battery in remote fob, possiable draw in system possiable fuse or possiable keyless entry module failure
I had the s500 2001... so u have to take the steel emergency key off then introduce it obliqually and push it will open! ...not easy to explain better but any mercedes service can help u easily and quickly!
Battery base has a device that clamps the battery on a step/notch on the side. Use a ratchet with an extension to loosen. Once it is loose you can remove the battery.
