Attempted to fax, canceled report, error code appeared and alarm flashes. Turned off and on. Unplugged and re-plugged to no avail.
Note :Be careful not to touch the components inside the printer.
(If the jammed paper remains in the printer, the paper may be automatically ejected.)
Paper jams inside the printer
(If you were not doing Duplex printing, you do not have to follow this procedure.)
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
The paper stock in the ASF will automatically feed the jammed paper from the printer.
If4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
Call our Toll Free For More 1 888 224 4280
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
