Question about Janome D'cor Excel Pro 5124 Mechanical Sewing Machine
Feeddog isn't working
The feeddog isn't working on my machine. It raises up and down but doesn't move back and forth to move the fabric along so the fabric stays in the same place.
  • 149 Answers
Your stitch length may be set to zero
Posted on Apr 09, 2010
SOURCE:
Feeddog singer stylist 776 how would the feeddog gt lowered
Consult the owner's manual. There should be instructions for how to darn with your machine. It would require either the feature that lowers/raises the feed dogs or a cover plate that attaches over the feed dogs.
If your machine came with the cover plate accessory, and the feed dogs are not rising to feed the fabric, then I suspect the machine has not been cleaned & oiled in quite some time and perhaps the feed dogs have seized. When you run the machine (remove the needle and presser foot), watch if the feed dogs actually drop below the needle plate, move toward the front of the machine, then rise above the needle plate and move toward the back of the machine. This is a repetitive motion that actually pulls the fabric through the machine. If this is not happening with your machine, it needs service.
Singer Stylist 776 Manual Page 8
Oct 30, 2016 | Singer Sewing Machines
My fabric dosnt move foward or back wards with the petal or manually ..
if the fabric won't move then there is something wrong with the
feed dogs, check in the needle plate to see if you can see the feed
dogs. you should be able to see them & touch them with your finger
since they are not moving the fabric it would be a good idea to
have the machine checked
I'm putting a link for a free manual for the machine, you can check
in the manual to see if it show where the feed dog lever is on the
machine, if it doesn't show a lever, or the lever is not responding to
movement then the machine needs to be checked to see what's
wrong.
http://www.singerco.com/uploads/download/463_2932_esf.pdf
Sep 04, 2012 | Singer 2932 Mechanical Sewing Machine
Won't sew, the fabric stays in one spot
is the problem the fabric is not moving forward but staying in one spot? which would mean the feeddogs need to be checked to see what position there in --up for sewing---down for darning
or the thread is not feeding into the machine?
Feb 10, 2012 | Janome DC3050 Computerized Sewing Machine
Machine will not move material under pressure foot. Thread get all bound up like tension my be too tight!
is stitch length setting correct, should be 2.5 for straight stitch. are feed dogs lowered for some reason? raise pressure foot and manually turn flywheel towards you while watching feed dogs. do they move up backwards and down? sounds like they are not feeding fabric through. check manual for how to raise and lower feeddogs if they appear to be down. sometimes its a button on base front or back of freearm. hope this helps out a little
Jun 06, 2011 | Sewing Machines
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Fabric stuck when sewing
Several things could be happening. It may be the hook/needle timing. Or it could be the feeddogs are not moving (that's the toothy looking part under the presser foot that moves the fabric). Recommend removing thread and bobbin (needle and presser foot). Slowly move the handwheel and put your finger on top of the feeddogs to determine if they are moving back and forth and are high enough to move the fabric. Check to make sure you had not manually lowered the feed dogs. You may need to take it to an authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Nov 21, 2008 | Husqvarna Viking 1
Brother vx 1120 Feeddog trouble
Have you tried the feed dog switch? If it hasn't been used for several years, a trip to a service man would do it the world of good, and he would be able to fix your problem too.
Oct 24, 2008 | Sewing Machines
Janome 9000
Remove the needleplate and clean out the lint from between the teeth of the feeddogs........it is the most likely reason, the lint holds the feeddogs below where they need to engage fabric.
Check your Presser foot tension is at 3 then do a test.
If this is not sufficient the method of adjusting feeddogs is possible at home, tho perhaps not for those lacking some confidence in mechanical adjustment.......so post back for detail if needed.
Jul 21, 2008 | Janome Memory Craft 9000 Computerized...
Kenmore sewing machine # 385.17626 feed dogs not advancing fabric. Appear to move up and down, but not forward to back.
I had the same problem and had recently posted my own message, with no replies. Took it to a repair person and he fixed it at no cost - it was stuck in reverse because the mechanism(s) were all gunked up. Take off the accessory box on the machine and the bottom plate. move the mechanism so they move freely and take out any gunk you see. The feeder dogs should now move back & forth in addition to up & down, feeding the material properly
Jun 21, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Feed dog & auto threader problems.
Remove the needle plate and clean the lint from between the teeth of feeddogs, also around and inside bobbin case.
The switch for the feeddogs is to raise (normal sewing) or lower (free motion) and if there is no difference, the accumulated lint will have made a felt pad between the teeth forcing the feeddogs to stay down and present with the problem you describe.
When things go a little "weird", the common instinct is OIL EVERYTHING............DON'T DO IT !!! ....this is rarely the solution on its own account, and can make the servicing a great deal longer as the excess must be removed........little oil regularly, not a bucketful every 5 years is a better approach.
Apr 23, 2008 | Brother LS-1217 Mechanical Sewing Machine
Janome D'cor Excel Pro 5124 Mechanical Sewing Machine Logo
121 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
