Copystar CS-1620 Copier Logo
wangu kamanja Posted on Apr 09, 2010
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
MY COPIER (KYOCERA 1635) DISPLAyS ERROR C6050. HOW CAN I CLEAR THE ERROR?
  • Anonymous Mar 19, 2014
    how can i reset error code c6050 in my photocopier km 1500
digivisionm
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Apr 09, 2010
digivisionm
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
18500
Points
81
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
I am Thomas from South Sudan my Kyocera Photocopier 1635 Series error code : C6000.What to do sir?
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
My Kyocera KM-1635 will not allow me type anything after displaying call center C6050
Fusing related problem
: Abnormally low fuser unit thermistor temperature
Replace Fusing Thermistor
Check Thermal cutoff
Replace fuser
1helpful
My Kyocera KM 1635 / 2035 displays error message: error call 600
Needs a service, either call your photocopier service company or find one on google.
3helpful
When powered on it displays error C -6 blinking, then it displays 000.
press 1087 1087 the display will show U000 the press 163 and press start , display shows CLE press start again the error will be cleared
42helpful
3answers
15helpful
Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
7helpful
3answers
Kyocera KM4035 Service Message C6050
the above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Top Copystar Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
