EZGO 27647-G01 when you try to go forward it just goes in reverse slowly. Put it in reverse and that goes fine. Any help would be greatly appreciated.
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Have ur shift selector switch checked or the linkage cable/ must be totally loose or slacking thats why it doesnt properly set on ur desired gear setting....
