Technics SL-1200MK2 Turntable Logo
Posted on Apr 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Technics sl 1200 MK2
Dont pawor on it sims that the transistor D1265 is bad so can i replace wef a noder
Grubhead
Level 3:
  • Technics Master 5,755 Answers
  • Posted on Apr 09, 2010
 Grubhead
Technics Master
Level 3:
Answers
5755
Questions
Helped
1662496
Points
11417
Yes and the good news is the 2SD1265 will cost you under a few pounds including P&P from Grandata Limited.
www.grandata,co.uk
Technic 1200mk2 pitch problems
Check for bad solderings on Q201 and surrounding areas.
Resolder IC101 and IC201. If that doesn't help, Q2 and Q3, both 2SD637R, could be broken. If that doesn't fix it replace the electrolytic capacitors. Cheers john. Styluscity
Technics 1200 mk2 just powered down and wont come back on
THERE ARE FUSES UNDER THE PLATTER AND BLACK COVER,REMOVE GLUE FROM AROUND REGULATOR DRIVER TRANSISTOR ON PCB.
1helpful
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
[email protected]
2answers
10helpful
2answers
How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
2answers
Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
