You can easily get blackberry storm mep code
from any mobile shop or from an internet source. Both are reliable
sources choose the source which suits you & kindly don`t ever try to
enter free Blackberry mep codes because if the code doesn`t works your
bb become hardlock.
Unlock Blackberry Storm
You can try at this link, and follow their direction to get your mep code. Usually mep code is needed when you want to unlock blackberry storm network, however if you want simple way to unlock your phone network try to use blackberry unlock code.
Hi
you cansolve this problem ...... very phone will have some imei number
and that phonecan be tacked by particular number if the is transfered to othernations
then that phonewill be in trouble because of this security system
to over comethis problem you need unlock code which is formed by some calculations of yourimei
you can go forcode generator but black berry is the most secured mobile
so instead oftaking risk you can contact the official unlock code provider and get yourproblem solved easily ........
ClickHere to get code after getting this type it in your mobile then you canuse your mobile anywhere ..............
