Power supply board it dead,replaced this board will get ur power back.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
Manually turn on the device (TV, VCR, etc.) to be controlled.
blinks once, then stays on.
Press the CHANNEL UP button repeatedly (up to 300 times) until the device to
be controlled changes channel. The red indicator blinks, then stays lit.
Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
Press and hold the SETUP until the LED indicator lights steadily. Release
Setup button.
Press the mode button that matches the equipment you want to identify. The
LED blinks once.
Press and release SETUP. The LED blinks once.
To find the first digit, press each number button from 0 to 9 until the LED
blinks. The number you pressed is the first digit of the code.
Press each number button from 0 to 9 again as above to find the second
digit.
Press each number button from 0 to 9 again as above to find the third digit.
Press each number button in turn to find the fourth digit. When the fourth
digit has been found, the LED goes out.
Setup button.
LED blinks once.
digit.
Setup button.
LED blinks once.
digit.
Code Search
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Code Search Method
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
Press the mode button that matches the equipment you want to identify. The LED blinks once.
To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
Press each number button from 0 to 9 again as above to find the second digit.
Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search Method
Hi, If Bravia tv wont stay On and shuts Off itself that means it got some internal problem, you will see red light flashing on tv front in specific blinking time that is an error code, let me know how many times that red light is blinking after three seconds long pause to diagnose problem. Thanks.
Three digit universal remote code for Symphonic Tv are:
033/ 053/ 189
Four digit universal remote codes for Syphonic TV are:-
0053 0189 0227 0456 0024
Four digit universal remote code for Symponic tv/vcr combo is
0227
Direct Code Entry
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Ok
hi.. It's in standby mode. Do a reset and see what happens While holding down the reset button on the remote Press the power button on the tv (The tv will turn itself off the back on) Now release the reset button
It sounds like the lamp needs replaced....
