1992-96 Models
Be sure this procedure is done in a well ventilated area.
Fig. 6: Pull back the rug under the rear seat to access the
fuel pump and sending unit cover
pipe from the pump bracket.
To install:
Hope this help (remember comment and rated this).
Can you use a davey pump in place of a fuel pump?
You need to remove the fuel tank for the fuel pump is mounted inside the tank
Hello avi1brar
Remove the lower section of the rear seat. Under that you will see a plate with several screws.
Remove the screws, then the plate.
Under that cover you will see the top of the fuel tank and the top of fuel pump sending unit.
Keep all sources of spark or flame away and a fire extinguisher handy would also be another good safety factor.
Undo the electrical harness connector and the screws retaining th sender to the fuel tank.
Carefully lift the fuel pump assembly out of the tank (careful, fuel will run out of the sender)
Reverse procedure to install using care to verify the seal for the unit and the mounting surfaces are clean.
KL
SOURCE: fuel pump relay
It is located above the glove box. It is the second relay from the left. If you pick up the chilton manual at your local auto parts store you will see the location and have the testing procedures for it.
SOURCE: how do you disconnect fuel pump on 1993 camry v6?
hi! there, disconnecting fuel pump,you mean dismantling or pull out the fuel pump to the fuel tank,fuel pump is located mostly inside fuel tank mostly there is access panel under the back set of the car or in the trunk of the vehicle,this means you wiil to lower fuel tenk from the car to disconnect/pull out the fuel pump.This can be a difficult job,so it's better to take your car in any service car facility center.
besides fuel is extremely flamable do not smoke when working on fuel sustem and keep any spark or other sources of ignition away from the fuel tank.
before moving fuel tank remove as much as fuel is possible inside the tank,use hand sipon pump to **** all fuel.there is drain bolt under the tank don't try to open this using wrench or electric bolter it might spark the fuel .donot **** fuel by your mouth by hose and by gravity to rdain out fuel is bad for heart..take all the necessary precaution handling job.double check under the back set if there an access opening w/o dropping the tank,if there 's one no need to lower the tank.
if no opening, lowerering the tankmake sure the parking brake is set,the transmission or tranaxle is in park position,and the front wheels are chocked with blocks or bricks for assurance no movement of car.raised the raer of the car with a safety jack,after raising support this by two jackstand for proper holding wieght of car.disconnect the filter neck from the fuel tank by loosening or removing the clamp that hold the hose on the tank.
Remove either the front two bolt or the rear two bolt that secure the fuel tank straps to your car.then gently lower one end of the tank.this will allow you to reach the wiring connection fuel line and vent hoses on top of the tank.disconnect wires and hoses before removing the two remaining bolts that hold the other end of the straps the lower the tank
if the tank is lowered on the ground,you can undo the plate on the top of the tank that holds the fuel pumps in place/the plate has a metal ring that has to be rotated counterclockwise to removed the ring the plate,fuel pump. and unit can be carefully pull out of the tank.
the fuel pumps that has been disconncted the fuel tank.regards ....
SOURCE: fuse for 1993 camry V6 fuel pump?
The fuel pump is controlled by the EFI fuse. If your car can go thru the RPM band in park or neutral, you do not have a fuel-related problem. What you may have is a transmission problem, or, the brakes may be seized. Does the vehicle "roll easily" if you push it? If not, a brake inspection is needed.
SOURCE: how do i replace the fuel pump in my 1993 mazda 626 2.5
1. Relieve the fuel pressure and disconnect the negative battery cable.
2. If not already removed, depress the clips on each end of the rear seat cushion and remove the cushion.
3. If not already done, detach the electrical connector from the fuel pump/sending unit.
4. Remove the attaching screws from the fuel pump/sending unit access cover and remove the cover.
5. Disconnect the fuel supply and return hoses from the fuel pump/sending unit.
6. Remove the attaching screws and the fuel pump/sending unit from the fuel tank.
7. Detach the sending unit electrical connector, remove the sending unit attaching nuts and remove the sending unit from the fuel pump assembly.
To install:
1. Attach the sending unit to the fuel pump assembly and install the nuts. attach the sending unit electrical connector.
2. Install the fuel pump/sending unit into the fuel tank with a new gasket and install the mounting screws.
3. Connect the fuel supply and return lines.
4. Install the access cover and the mounting screws.
5. Attach the sending unit electrical connector.
6. Position the rear seat cushion over the floor, making sure to align the retaining pins with the clips. Push down firmly until the two retaining pins are locked into the rear seat retaining clips.
7. Connect the negative battery cable, start the engine and check for proper system operation and for fuel leaks.
