You probley need to cleen the condensor coil
Testimonial: "Thanks, I will clean the coil asap and see what happens"
If the filter is clogged up with a lot of debree/Dirt and other fibers it will cause the machine to overheat amd automatically shut down to prevent a fire. Clean the coils and the filter thoroughly at least once a month, and I think the problem will be solved!
I have this problem also. I cleaned the filter but how do I clean the condenser coil? Where is it located?
