Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Posted on Mar 17, 2008
Washing machine won't drain
Top load washer, fills up, agitate, but stops, wont drain or finish out cycle to spin dry.
  • 1 more comment
  • Old Blue Mar 30, 2008
    Washer will not drain or spin in the spin cycle.
  • Old Blue May 11, 2010
    How do you remove the cover to look and repair the machine?
  • michelle hill
    michelle hill Mar 09, 2017
    i have an haier top loader, its doing the exact same thing. fills,agitates, but then wont pump out water to finish cycle. and the spin cycle works, we checked.
    someone said something about the switch in the lid?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
321
Points
Replace the lid switch. that's what i have to do with mine. i researched it a few weeks ago. Simple cheap fix - i think it was about $20
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
33helpful
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
7helpful
2answers
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
