Question about Kohler Sunward K-1164-H-96 Biscuit 6 Feet Whirlpool with Heater
Can I add a inline heater to a Kohler whirlpool 1164?
  • jimrkrieg Apr 10, 2010
    I asked whether a heater can be installed. This unit was purchased without the inline heater.
  • 745 Answers
In looking at the spec sheet for this model, it appears that a heater is already installed at the factory. See this link:
http://www.us.kohler.com/onlinecatalog/detail.jsp?item=9737602&prod_num=1164-H&module=Bathing&frm=null
If the whirlpool isn't heating, the power to the heater, thermostat, and the heater itself should be checked.
Posted on Apr 09, 2010
  • jdthefixer Apr 10, 2010
    If the unit was purchased without a heater, then there is room for a heater. Contact your local Kohler dealer or a home improvement center to obtain a heater kit.
SOURCE:
How to replace a gas waterheater
1) Copy following link for step-by-step replacing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/pdf//Which-is-best-gas-water-heater.pdf
2) Add a comment Feb 2013 for more help as needed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 26, 2013 | Kohler Water Heaters
Wiring diagram on whirlpool gas water heater
Whirlpool is AO Smith tank-type heater.
Year, model, type of heater not known.
So add a comment and then expert can look up the manual.
You probably have power vent, or dampered water heater, otherwise the only wiring would be for thermopile, thermal reset, and igniter.
Power vent, or dampered, of flow control water heaters plug into outlet, and wires from gas control run to the various components.
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/Review-AO-Smith-Effex-water-heater.html
Don't forget to add comment and include model number that shows on label located side of tank.
Sep 21, 2012 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
I am looking for a manuel for a whirlpool hot water heater model number fg1f3030s3pv. I tried to contact sears direct but they did not have one for that model. They told me to try going onto...
1) Whirlpool is a good water heater. Add a comment any time and describe the water heater gas control valve and other features for best possible resources. Many of the new Whirlpool gas heaters arrive with Honeywell electronic gas valve.
2) Web search for fg1f3030s3pv water heater turns up generic gas water heater manual showing dial-type gas valve, piezo igniter, with good section on parts and repairs, and a troubleshoot checklist:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0603477.pdf
3) Whirlpool is made by American water heater, Oct 2011.
Open following links for more manuals.
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
http://www.americanwaterheater.com/support/manuals.aspx
4) If you are trying to fix the water heater and want other resources.
Also add a comment with specific description of problem and what you have done so far:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Whirlpool-Resettable-ECO-20.jpg
5) Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 02, 2011 | Water Heaters
Energy saving devise light blinking and no hot water
Water heater is not identified.
Add a comment with information that appears on label on side of tank for possible help.
You might be talking about Whirlpool energy smart electric.
The error diagnostic lights flash a code: the code decipher is printed on the diagnostic control box on top of heater.
Call Whirlpool: you need model number and serial number from label located on side of tank.
1-877-817-6750
Open following links for energy-smart resources and typical manual:
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
Aug 04, 2011 | Whirlpool Water Heaters
I NEED THE EXPLODED VEIW TO TAKE OUT DRUM OF WHIRLPOOL WASHING MACHINE 3953296
http://shared.whirlpoolcorp.com/product_literature/search.jsp
This is where you will find the literature for your unit if they have it. Otherwise, you will need to contact them directly.
Apr 06, 2009 | Kohler Sunward K-1164-HB-G9 Sandbar 6 Feet...
When we press the "on" switch in or Kohler whirlpool tub it trips the wall switch. I changed the wall plug and it still trips when trying to turn it on. It has always worked fine. Any suggestions..
Remove the GFCI WALL OUTLET and try connecting those wires together blk/blk..wht 2 wht...ground to ground and then see if tub will stay on, if not suggest put back together and call qulified whirl pool tech to find short in pump motor.
Please rate. Thank you. jj505
Mar 28, 2009 | Kohler Synchrony K-1192-LH-0 White 5 Feet...
Heater doesn't work correctly
I think the pump is going out on reset or hi limit
Mar 13, 2009 | Kohler Riverbath Quadrangle Whirlpool w/...
Kohler Sunward K-1164-H-96 Biscuit 6 Feet Whirlpool with Heater Logo
485 people viewed this question
Top Kohler Water Heaters Experts
Donni Steen
jdthefixer
Todd B
Are you a Kohler Water Heater Expert? Answer questions, earn points and help others
