The wheels on my son's Leap's Phonics Railroad train have stopped working. The two main wheels that drive the engine are stuck and only make clicking noises when forced to move. The train moves around on a track, but now it is unable to move.
Is there anything that I can do?
SOURCE: the track ball on my blackberry 8310 stopped working.
No, but fortunately the trackball is not hard or expensive to replace. If you are technically savvy you can do this yourself. Just purchase a trackball on the internet. The trackball easily comes off if you put a small flat screw driver under the outer side of the chrome ring and pull if off. Let me know if you needed more help. Good luck
SOURCE: Sprinkler will not move forward properly
I have 2 John Deere 4010 traveling sprinklers and they both do the same thing. I took them apart and the plastic worm gear has flat spot on them. I am having difficulty finding replacement parts.
SOURCE: little tikes princess battery power wheels
I would replace the gearbox, but it is a specific little tikes gearbox. If it is making a grinding noise, then the gears have broke.
You can find them at this website
http://www.shopjandl.com/884931300.html. I would just let them know what model it is and you should be good to go.
SOURCE: Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
SOURCE: thumping noise in front drivers side wheel and
Check your suspension bar and check your front strut assembly, jack up the side you here the noise on and pry against the tire to see if you have any movement between the strut housing and the frame, make sure the top strut nuts are tight, if they are next check tie rod ends to see if you have any play, next pull the wheel from the top and bottom to see if it's loose if it is watch while someone else wiggles the tire, you could have a tie rod loose or a king pin loose. Also it could be a wheel-bearing nut. Let me know what you find so I can tell you how to replace it.
