SOURCE: zebra lp 2844 prints a blank test page
possible was reset to factory defult and the darkness is to low, press the button until flash 5 times and let run untill see the dark print. then press the buton again. Try to print again (flash 1x)
outher possibility is the ribbon in on other way.
other possibility is the labels need to use ribbon (Thermal Transfer), and the printer is run out from ribbon.(run as Direct Termal.
SOURCE: Zebra LP 2844 prints blanks
In addition to jigeo solution you need to know this, the little taken- sense button must be in the off position before this procedure works. You can then return it to the on position.
SOURCE: Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
SOURCE: Zebra prints one page then light turns red.
TRY HOLDING THE BUTTON DOWN AND LET IT FLASH 5 TIMES. RELEASE. WHEN THE DIMENSIONS ARE AT THE CORRECT NUMBER PRESS THE BUTTON AGAIN.
SOURCE: how to configure zebra lp 2844 to ups shipping
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.html
Download the entire manual with this link.
Hope this helps! If so, please leave a rating!
