Air Tools & Compressors Logo
Posted on Apr 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is half of -.5 and 2.0 - Air Tools & Compressors
Anonymous
Level 2:
  • Expert 332 Answers
  • Posted on Apr 08, 2010
Anonymous
Expert
Level 2:
Answers
332
Questions
0
Helped
140827
Points
780
  • Anonymous Apr 10, 2010
    Or .75 depending on who you do the math
2answers
Why does 1/5 + 1/2 not equal 2/7?
Let's look at the overall picture. Does it make sense if you have a fifth of a pizza and add a half pizza, you get less than a third of a pizza.
Now, into the math.
Here is a fifth of a pizza.
fifth pizza-t3nl2udzxv0orsigcra1nwzp-2-0.jpg Here is half a pizza.
It is hard to add these two.
We find the least common multiple of the denominators 2 and 5 and get 10.
Let's redo the pizzas in 10 slices.
And the half pizza.
Now with the same sized slices, we can add the slices and calculate the result.
seven tenths-t3nl2udzxv0orsigcra1nwzp-2-14.jpg Now we have seven slices out of ten, or 7/10.
Good luck.
Paul
Jan 04, 2017 • Homework
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
What is half of 5/8
Half as a fraction is 1/2. In math, "of" means "times." Combining these, 1/2 x 5/8 = 5/16.
Amp goes to half power? Even after tube replacement.
How do you know it is going half power? did you measure this, or do you only hear half the power? because then also a speaker (or more) could be not working.
Aeg competence d8800 5
Electronic component failure. As only 5 years old then worth calling a Service Engineer.
Sep 18, 2017 • Ovens
2helpful
2answers
How many quarts of oil does a Corolla Dx hold at oil change?
4 quarts, 5 with filter change according to the book. Rule of thumb, buy 5 and once you drain and replace the filter, start by putting 3 and a half quarts in and check the level. If it's between the marks start the motor and run for 5 minutes then let it sit for 5 minutes and recheck the level. Top off half a quart at a time till you get the oil level between the full and add marks.
Washing machine
green and yellow is earth so wire the earth wire to this. brown is live in and blue is neutral in. brown/white is live out and blue/white is neutral out. usually a suppressor capacitor has a diagram printed on it
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Top Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
