SOURCE: wii console error
Is it just one game that does this? Does it happen in the middle of a game or right away? Is the game an import?
I would call Nintendo on this one.
SOURCE: We are getting the following
well I have 3 kids and let me tell you this I had this happen a few times to me and guess what it was? the kids put the disk into the unit the wrong way.
Also as far as your case if it is not working 100% then it could be the lazer is out of alignment as well which is fixable.
SOURCE: an error has occured
Either you are using a backup in a non modded machine or if it is modded you will need to install gecko OS or similar
SOURCE: Message - An error has occured. Press the Eject
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
cholona19
SOURCE: wii says An error has occurred. press the eject
Your discs might be scratched, the disc reader might be faulty or dirty. You should try to clean both the disc and the drive.
