I have a used presario700Z laptop with winxp home ed. While trying to learn about this computer and the xp program (new to me) I somehow have lost the botton taskbar and start button and notification area.(the whole botton line) , also the icons on desktop. I tried to right click on the desktop to bring up the properties menu and the right click does nothing. Any help on this will be greatly appriciated. I have no manuals jut machine and power cord. Thanks.......sugarpie925
the start menu is not working and there is not a thing on my desktop so please helpthe start menu is not working and there is not a thing on my desktop so please help
You can't post conmments that contain an email address.
Press Ctrl+Alt+Del when it stops at Blank Desktop.. Go to "New Task", Type "Explorer" at "Run".. if the problem occurs, you may have to repair your windows... follow this step...
Take your WINXP Bootable Installation Disk, Boot it, Repair your system (First Repair Option) using repair option.. Thats all.. Your previous settings will not be disturbed.
Hi,<br /><br />I think you need to uninstall and reinstall your HP printer drivers.<br /><br />to do this follow these steps:<br /><br /> 1.<br /> Select Start , Settings , and Control Panel .<br /> 2.<br /> Double-click the Add/Remove Programs utility.<br /> 3.<br /> Select the HP Deskjet D2360 Printer and click Add/Remove<br /> 4. Restart your computer<br /><br />To reinstall HP Deskjet D2360 Printer<br /><br /> *<br /> Make sure that the printer is properly set up, turned on, and ready to print.<br /> *<br /> Check that all cables are firmly connected.<br /><br />For Windows XP<br /><br /> NOTE: You must have administrator privileges in Windows XP Professional to install a printer driver.<br /><br /> 1.<br /> Close any unnecessary programs that are running on the computer using the steps below.<br /> 1.<br /> Right-click any program appearing on the Taskbar next to the Start button and choose Close .<br /> 2.<br /> Repeat step a. until all the programs appearing on the Taskbar are closed.<br /> 2.<br /> Click Start , Printers and Faxes , and then Add a Printer .<br /> 3.<br /> Follow the instructions on the screen to finish the installation.<br /><br />For Windows XP Home Version<br /><br /> 1.<br /> Close any unnecessary programs that are running on the computer using the steps below.<br /> 1.<br /> Right-click any program appearing on the Taskbar next to the Start button and choose Close .<br /> 2.<br /> Repeat step a. until all the programs appearing on the Taskbar are closed.<br /> 2.<br /> Click Start , Control Panel , Printers and Other Hardware , Printers and Faxes , and then Add a Printer .<br /> 3.<br /> Follow the instructions on the screen to finish the installation.<br /><br />If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response<br /><br />Thanks,<br /><br />LETMEFIXIT
If you have another computer available you can make a bootable cd that will run a program to reset your admin password. Several of those programs are discussed here. Good luck to you.
When you install a new harddrive, it has no Operating System on it. Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive. Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it. Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista. If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista. Tigerdirect.com, and Newegg.com, have these. Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
This situation leads me to believe that the CD or DVD drive is faulty,,or the install disc you are using is scratched or dirty. Try cleaning the disc and begin again. Another option is to take the hard drive out and using a 2.5 to 3.5 inch HD adapter ,,plug into a desktop PC as a slave. And copy your WinXp cd onto a partition on your laptop HD. Then using a Win98Se floppy boot disc you can access the winXP and install from there.
i think your system might have got attacked with the virus so just get the updated antivirus installed and get it searched and fixed .... if problem persists just reinstall the operating system ...
If you have access to another computer where you can download and burn
a program to a CD I can help. I have a program to remove all passwords
from Windows XP but it has to be burnt on to a CD and then you boot from
that. Enter the options on screen to remove any passwords, then remove the CD and reboot in to Windows. It does not affect any of your programs or files. you can email me here if you are interested [email protected]
In order to update your system from the current Windows operating system to Windows XP Home, there are several steps that need to be taken prior to upgrading. Please follow the items listed below in order to prepare for Windows XP.
Uninstall Trend PC-cillin2000
Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel.
Double-click the Add/Remove Programs icon. Click install/Uninstall tab, select "Trend PC-cillin 2000".
Click the Add/Remove button to uninstall "Trend PC-cillin 2000".
Uninstall NTI CD-Maker 2000*
Double-click the Add/Remove Programs icon. Click the Install/Uninstall tab, select "NTI CD-Maker 2000".
Click the Add/Remove button to uninstall "NTI CD-Maker 2000".
Uninstall Intel LANDesk Client Manager*
Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "Intel LANDesk Client Manager 6".
Click the Add/Remove button to uninstall "Intel LANDesk Client Manager".
Uninstall PowerDVD*
Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "PowerDVD".
Click the Add/Remove button to uninstall "PowerDVD".
* This software is optional. If this software is not installed previously, please skip the step.
