Question about Frigidare PLGC36S9EC 36 in. Portable Gas Cooktop
All valves off but igniters keep clicking. - Frigidare PLGC36S9EC 36 in. Portable Gas Cooktop
  • Frigidare Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 19, 2010
SOURCE:
My gas cooktop is contiuing a clicking sound to start the gas burner. it is not the color of the flame or that stuff. Just the starter keeps trying to start. the gas burner that is all. Blair
Hello Blair
Does the clicking or spark stop with all knobs in off position? If so it's probably the one burner valve for the one you're trying to light ,stuck in light mode,sending signal to module.Have that burner valve replaced.($50). (2) If clicking continues even though everything is off, it could be any one of the burner valves or your ignition module is messed up .You would have to pull wire off each burner valve one by one to find the offending valve . If not valves then suspect ignition module.
Easily fixed either way.
Feedback appreciated !
Aug 03, 2011 | GE Cooktops
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
Igniter will not turn off. Makes a clicking sound
Hi, normally what causes the igniter to keep clicking is spilling water or something down into the knob area. The water is causing a short circuit in the switch which is mounted on each burner valve shaft. If unplugging the range for several days to allow drying doesn't fix the problem, then one of the switches will need to be replaced.
Jan 27, 2010 | Magic Chef Cooktops
All 4 igniters keep clicking, when one is on
All of the igniters are connected to one source. A series of small switches mount on each stem of each burner. Any of them can fire up the spark box and it in turn it fires off all the ignitors. If a boil over spills liquid into one or more of them switches the resulting continuity causes the clicking. Removing one wire at a time from each switch till the clicking stops is the solution.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 05, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Igniters will not turn off
Your switch assembly on the valve shaft has come loose or has broken. Have a look.
May 23, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
Apr 15, 2008 | Cooktops
Frigidare PLGC36S9EC 36 in. Portable Gas Cooktop Logo
126 people viewed this question
Top Frigidare Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Frigidare Cooktop Expert? Answer questions, earn points and help others
