Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor Logo
Posted on Apr 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen wont come on
Green light stays on, goes to amber, blinks then back to green
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Apr 08, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368239
Points
33650
I assume that it does have the same problem when it is attached to other PC.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find so we can guide you furhter.
1helpful
Optiplex 755 blinking amber light, simple solution, I'm no IT professional.
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.A power supply or system board failure has occurred. Try to isolate the problem by removing or disconnecting all cards, i.e. video, sound cards and disconnecting CD/DVD and hard drives.
Front signals work but back ones wont blink and im not sure which bulb is sapost to blink. i checked my fuses, it was good.one of my side marker bulbs is out, could that be it? Its a 1997
It only takes one bulb to blow, that side wont blink, it will stay on, blinker lights have amber lens or amber globes if you have clear lens.
Power light is blinking green and amber
my power light flashes green/ amber as soon as it is plugged in, with a dead battery. It seems to go to steady amber if the plug is tapped, but goes back to flashing. It will not hold a charge on a new battery.
2answers
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
4helpful
2answers
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
1helpful
2answers
JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
3helpful
3answers
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Top Planar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
