Help. I don't know where to start. I've tried to check the manual. It's not helpful. We bought this refurbed and I have a disc, but it's not the manufacturer's disc. I need help.
Konica Minolta machines have many manuals. You may not have the correct one for network setup and settings. To setup scanning you will need first to setup the machines network settings before any One Touches will work. Try kmbs.konicaminolta.us You can download all manuals in PDF format.
On machine touch the following
utility
one touch
one touch
new
touch smb/pc
touch name and enter a name
touch down arrow (go to page 2)
touch reference
touch either the domain or the workgroup your computer is logged into
touch open
browse to your computer
touch open (after highlighting your computer)
If user id/password blocks pop up then enter the name and password that you login into the computer with
browse for the folder you want to use.
then hit ok
this takes you back to the page 2 screen with everything set for you.
hit ok then hit close until you are back to copy screen and try.
This is the steps I use and it works 99% of the time. Also if the system admins have turned smb protocol off then you cannot use it. You will need to use another method.
Luanne, What is it that you need assistance with doing?
