Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
Posted on Apr 07, 2010
How do i change the language on my washing
How do i change the language on my hotpoint ultima wdd960 washing machine?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6105
Points
21
Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
  • Anonymous Jan 11, 2013
    I have done that and it does not work I have a Eco tech 9kg ultima
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 03, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7201
Points
Instead off the L buttons as described in the instructions Booklet DO THIS:- with the plug socket on you must turn machine off (no display) then Press and hold the spin. delay start, temp select buttons altogether for over 5 sec untill you hear a beep, the language menu comes on, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button z once.
    This one helps a lot better thank you my washer is know back to english
  • Anonymous Sep 20, 2016
    I tried Hayley's suggestion and it worked perfect, but Scoopy's didn't with mine
Anonymous
Level 1:
New Friend:
  • Posted on Oct 17, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6105
Points
Instead off the L buttons as described in the instructions Booklet DO THIS:- with the plug socket on you must turn machine off (no display) then Press and hold the spin. delay start, temp select buttons altogether for over 5 sec untill you hear a beep, the language menu comes on, then release all 3. press the temprature start button to scroll through the available languages then select your chosen language by pressing the drying button z once.
Anonymous
Level 1:
New Friend:
  • Posted on Jan 11, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6105
Points
How do I change the language on a Eco tech 9kg ultima please
How do i change the language on my hotpoint wmd942
To fix it switch the machine off, then push and hold the middle 3 of the 5 function buttons below the display until it beeps, and then turn on. You can then set the desired language from a menu, using the right hand buttons to move, and the top left button to confirm
3helpful
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
1helpful
How do i change the language on my hotpoint wmd960p washing machine. The language is currently set to french and i want it in english
Hotpoint kindly omit this from the manual. Love 'em!
I believe that You hold the i (info) button and delayed start button simultaneously for five seconds, then the screen reverts to the language choice page. The machine needs to be switched on.
Drop me a note back if this doesn't work
14helpful
3answers
My washer is in french wdd960 how do i get it in english?
To change the language on the Hotpoint WDD960P/G/A/K washer dryer.
The official manual is slightly wrong!!
So Follow these steps:
With the machine in the "OFF" position (NO display) Simultaneously press and hold the Delay+Temp+Spin buttons until you hear a bleep and a language is displayed. Let go of the buttons and scroll to your desired language by pressing the "Spin" button until the language you want is displayed.
Inmediatly press the "Drying" button to select it and the display should say "Hello" to acknowledge the selection.
If you take too long in pressing "Drying" it reverts to the previous language.
Happy washings!!!
17helpful
2answers
Hi,how can i reset the language on my wmd960 hotpoint ultima,thanks
1. Switch on the power and when the language is displayed - press the child lock+ temperature+ spin buttons simultaneously for about 5 seconds. Release the child lock button when other languages appear. Scroll down using temperature button-until English is dispalyed. Select using child lock button.
I can't change the language on the washing machine. How do I change it??
Key
wms=washing machines
wm=washing machine
IFYOUCANREADTHISTHENYOUSHOULDBEABLETOREADTHEFOLLOWING:
YOU CANNOT CHANGE THE LANGUAGE ON ANY WM.
1helpful
2answers
Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
