HP Photosmart C6180 All-In-One InkJet Printer Logo
Posted on Apr 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If I open and close the printer it starts as if it is doing printer prepeartation, but nothing comes on. The screen will not turn on.
Anonymous
Level 2:
Novelist:
  • Expert 91 Answers
  • Posted on Apr 07, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
91
Questions
0
Helped
59436
Points
218
  • SOLUTION 1 If the HP All-in-One is turned off, press the On button to turn the unit on.
  • Unplug the power cord from the back of the HP All-in-One.
  • Wait 15 seconds.
  • Plug the power cord back into the HP All-in-One.
  • Turn on the HP All-in-One by pressing the On button.SOLUTION 2: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    1. Unplug the power supply from the rear of the product.
    2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
    3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
    4. Wait 15 seconds.
    5. Reconnect the power cord to the power module.
    6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
    7. Check to see if the power module has an LED.
      • If the power module does not have an LED, continue to the next step.
      • If the power module has an LED, check to see if the LED lights up.
        • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
        • If the LED lights up, continue to the next step.
    Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
    1. Reconnect the power supply to the rear of the product.
    2. Press and quickly release the Power button (If I open and close the printer it starts as if it - c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down.
  • Add Your Answer
    Canon MP340 won't scan
    The printer "black ink low" message has nothing to do with scanning. You don't have to disable the ink monitoring or do anything else with printer - to scan!
    The printer is" waiting" for you to CLOSE a "Paper port 11" dialog box on your PC screen. If the dialog box is not open, check the task bar (bottom of screen) for anything with "MX340" in title, click on it then close it.
    good luck
    Lumir
    www.inkbank.com.au
    Print carriage access door is open or ink cartridge cover is open. getting this message but nothing is open!! It says to hold down ok button for 5 seconds but nothing is happening. I turned off but it...
    Turn off your printer
    Open the cover
    1 move the cartridge carrrier manually to the center manually with your hands from left torgiht ( 5x )
    2 .Remove the cartridges used a clean paper make sure its dry wipe the area where the ink goes out make sure its clean .CLean also the area where you return your cartridges make sure its clean OK .
    3 >return it properly close the carrier properly make sure there's a snap sound produced .Move again the cartridge carrier manually from left to right 5x
    close thecover
    try to turn it back on
    in case nothing happens
    remove all the parts cartridge ,black box paper power supply
    lift the printer up turn it up side down make sure the cover is open when you lift it up and turned it upsidedown
    so any foreign material will come out
    Shake it for 5x
    \return all the parts
    try to power it on
    Hope it help thanks
    Turn printer on ERROR comes on screen. Carriage jam Open Door clear carriage jam and then press OK to continue. I do this nothing found in carriage close Error comes up the same?? What to do?
    Joe,
    Pull all of the paper out of the machine. Look for a wadded up small piece of paper. After you look for it. Examine the door slide tray where paper is stored. Look at take-up rollers... make sure slide drawers close easily...examine door where print cartridge is....Look at (on side) feed tray...Paper feed tray... If you fail get a flashlight and take another look it does not have to be a very large piece of paper...good luck
    4helpful
    C-0991 error on screen
    First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
    So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
    Then open and close the large front door to reset the code.
    If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
    Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
    You can use the copier by leaving this tray open if need be.
    Good Luck.
    The screen on my Lattitude 120L won't come on after I close it
    goto control panel click on DISPLAY then screensave then POWER SETTINGS and on the left side there is a section called what to do when i close my lid click on that and for lid settings click on do nothing so after u close ur lid it wont disable ur screen
    email me at [email protected]
    names mark
    2answers
    Laptop screen goes dark.
    Is your computer setup to go to sleep when you close the lid?
    Click on start -->control panel-->power options and then check the option that says choose what closing the lid does. You have to change this setting to 'do nothing' if you want the computer to stay on when you close the lid.
    Display will not show when tv flips out!
    MOST SCREENS R NOT ON IN THERE RESTING STATE, THERE USUALLY A MECHANISM THAT TURNS THE SCREEN OPEN WHEN IT OPENS, TRY SLIGHTLY PUSHING THE SCREEN BACK LIGHTLY TO SEE IF IT COMES ON HOWEVER IF U CAN RESET IT , TRY THAT IF THAT DOESN,T IT WOULD HAVE TO BE REPAIRED FROM THE MANUFACTURE
    1helpful
    When i send a print nothing happens. I opened the lid to check for a jam. nothing. but when i closed it the screen on mu printer says carriage jam.....
    Sounds like the "deadly embrace" problem...
    Computer says to itself "waiting on printer status"
    Printer says to itself "waiting on computer status"
    Results....nothing.
    Try this:
    1. Shutdown (using the normal operating system shutdown) the computer.
    2. Turn off and unplug both the computer AND the printer at the same time.
    3. Plug the printer back in first (and if necessary, turn it on) THEN
    4. Plug in the computer and allow it to start normally.
    Now try a print.
    Let me know if this works for you.
    2answers
    Open/Closing
    CONTROL PANEL --> POWER OPTIONS --> ADVANCED TAB
    Select "When I close my lid (or something to that effect)" and change it to "do nothing" or "ask what to do". There is nothing I hate more than a misbehaving hibernation mode!
    2helpful
    Close top cover
    Start by trying this.
    Open the cover and look around for openings in the where the cover closes. In those openings there are interlock switches. 1 of 2 things have happened.
    1, The switch may have become dislodged.
    2. Look on the cover you have opened for actuators, ( pieces of plastic sticking out) that would go into those holes to turn the switch on when closed. Those often break off.
    One of those 2 items is your problem, The switch is just not being actuated properly.
    Make sure nothing is binding the cover also.
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
