Archos 404 Digital Media Player Logo
Posted on Mar 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fix my archos 404
I have a problem with my archos 404, the screen has been cracked badly and its now blank that u can't see anything and play anything. any way i could get it fixed
  • noginator Apr 06, 2008
    my archos took an epic fall and now the camera does not show on the screen when i take pictures or camcord. can i fix it? thx =)
  • normawilson5 Dec 06, 2008
    i had the same thing happen to mine have looked everywhere to get it repaired but cant find anywhere i think it would be better to buy new one
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Mar 17, 2008
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564689
Points
12312
Can it be fixed, yes. However, the replacement panel will probably cost $150 or more. Given that the original cost of the player is $179, I don't think it is worth it. The labor cost will make the repair exceed $179.
Dan
My archos 5 IMT 160 gb has a blank screen. It looks like is charged. I makes noise while is starting up, but the screen is blank. I* charged for over 10 hours.
Screen is blank?
Do you mean you won't see anything at all like the signup colorful screen that says "ARCHOS Entertaining your way" ?
If your battery is full charged (did  the CHG LED green light blink when it finished charging?), and you have a blank screen, do you have a serious problem indeed. If your unit is under warranty your best and only way is contact Archos.
If when you turn it on, it takes you to the Recovery screen (white screen, usually says Code 101) then try to Format the HDD, download the latest firmware from www.archos.com for your unit, copy it from your PC to the Archos, let it finish the process wth the power supply connected, and once it's done the unit should be back working fine with the latest fimware.
But if you definetely do not see anything but a blank screen when you turn it off, your problem is more serious than a simple firmware upgrade, and you need to contact Archos tech support.
I have a crack in the middle of my screen..it still works properly how can i fix this?
You cannot fix lcd screens. You can only replace them I am sorry to say.
My archos 404 has got viruses and it can't be formatted
have u got and anti-viruse on up pc, does the archos still connect up to the pc. try this first if not try the reset then try to format. i need to know a bit more to help
2helpful
5answers
Broken screen
i have the archos 404 with a crack screen need to get it fix
My LCD screen on my Archos 404 broke i know where i can get a replace ment (newmp3technology.com) but i don't know how to fit it in to archos. can you help, thank you
1. get a LCD screen from newmp3technology.com
2. use a bit of card or credit card and slide it between the LCD screen and the front this removes the glue
3. remove four screws on the sides
4. remove the back
5. lift the battary and unplug
6. lift the hard drive
7. remove the two screws in the corners
8. now you can remove the front
9. lift the LCD screen so you can see the cables
10. slide the cable out of its housing
11. to put the new screen in follow numbers 10 to 3
when removing the glue or the front of the archos do not touch the LCD screen as now its not fixed it will brake
Archos 404 problem
have you tryed the reset its a little hole on the top next to the word archos. your data should be ok but it would be wise to back it up if you can.
1helpful
404 is frozen
In the event that your ARCHOS device freezes operation
(due to electrostatic phenomena, for example), you can reset it
by pressing the button for 15 seconds.
My archos 404 says to play video with mpeg1/mp2 i need to purchase a software plugin which is available at www.archos.com
Just convert the movie to MPEG4 ASP (Level 5), XviD, DivX 4, DivX 5 or WMV9 (max resolution of 704x 480 @ 30fps, 720 X 576 @ 25fps) format on your desktop computer an then load it onto Archos
1helpful
Archos 404 hard drive
Cannot replace yourself - unfortunately
Archos Screen
Reset by holding down power button for 15 count then repeat to turn back on, or hit the button below to unlock LCD screen.
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
