Can you please update this with your connections. I assume that you are connecting the turntables to the mixer? Verify that the mixer is set to send out true stereo. What mixer are you using?
Note that most mixers "pan" all of the channels to the center sending out mono to the left and right. In most live shows, it makes no sense to send out true stereo. The left and right are for the speaker chains. In order to get true stereo out of the mixer, you wil need to pan the input channel for the left side all the way to the left and the input for the right channel to the right.
Dan
Thanks for the reply, Im useing an Allen & Heath xone62, i think there is a problem with the cd recorder itself. There is a display on the front which gives you the sound balance and it only works on the right. When recording and playing back it will only play on 1 speaker if that makes sense.
Thanks Dan im using XLR cables and there in perfect order. What is "Y" cable?
