You should NOT be able to damage the unit by reversing in and out on MIDI connections.
MIDI connections are fairly safe against damage unless you drive a ground loop into the output ones.
ALWAYS operate any connected equipment from the SAME power source receptacle.
Fopr instance, do NOT have a musical device powered froma wall receptacle across the room and connected to a computer on the other side as an example.
Testimonial: "Thank you very much for your help. After I let the Alesis SR16 rest for a while it started to work again."
