Touch screen unable to recalibrate to fix. Device screen is stuck on on the " I agree" terms of usage page. Was able to reset device but then turns off before it recalibrates(holding the power button 30 sec.)
Usage page Shows a page count for each size of paper printed, the number of one-sided (simplexed) or two-sided (duplexed) pages, and the average percentage of coverage. 1. From the Home screen, touch Administration. 2. Touch Information. 3. Touch Configuration/Status Pages. 4. Touch Usage Page. 5. Touch Print.
I've similar question. My ipod touch 2 screen is very finicky! It sometime responds just fine, but other times requires multiple taps before it does it's duty. Is there a fix for this? I have tried soft resets and recalibrating. The recalibration works fine, but I don't think it should have to be done daily which is about what I'm doing now. Is there another more permanent fix for this problem?
Seems the X/Y axis is misaligned from the device being dropped or excessive pressure applied to the touch area. Recalibration won't work because there is a physical condition Vs mechanical or other issues. Touch screen replacement may be the only option.
Hi,the problem you are experiencing with your GPS device can be solved by simply recalibrating the screen.this is how you recalibrate the screen of your device;
1.Touch "display" .
2.Touch the "recalibrate" button,then follow the on-sreen instructions,until you are done.
Try recalibrating the touch feature. Touch screen devices need to be recalibrated ever so often. The more it is used, the more often recalibration should be done. I recalibrate my LG VU once a week. Hope this helps.
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
This doesn't fix Sitfar's problem, but for those how might find this helpful from Garmin's site:
Question: The touch screen is not responding correctly when I touch it. How can I recalibrate the screen?
Answer:
To recalibrate the touch screen:
Turn the unit off.
With the unit off, touch and hold the Power button for 30 - 40 seconds.
