This printer is just over a year old and it has no power. I've tested the power adapter and it is good. I would like to get instructions on how to take it apart so I can try replacing the power supply. Any ideals would be helpful. I hate to just throw the printer away. I've never even had to replace the ink cartridges.
Yes i have the same problem. I have had mine for 2 1/2 years. Working fine, today i try to power up and no power? I hear small kinda sound in the back but nothing turns on.Yes i have the same problem. I have had mine for 2 1/2 years. Working fine, today i try to power up and no power? I hear small kinda sound in the back but nothing turns on.
You can't post conmments that contain an email address.
> connect the power chord directly to the wall socket.
> try with different wall socket.
> u said that there is no problem with the adapter, that means the light is lit on the adapter. so there should not be any problem from the wall socket till the adapter.
> check the connection from the adapter to the printer
> make sure that it is securely plugged in to the printer as well as to the adapter.
if nothing happens you can try changing the adapter. because the problem may be on the part which lies from the adapter to the printer. if that is also not working, you may have to service the unit.
I am afraid that Dennis (Writing below) is correct, When you have smearing it is a print head problem and they need to be replaced, If you have had this printer for many years (HP GOOOD Printer) you should check prices on a new machine, the reason for that is that HP has discontinued support on many machines as of 1 Jan 2013, If you can find a print head for your system it may be half the price of a new machine, Also; if one print head is going it may not be long before you see the same problem on the one or more color print head. It is probably not what you were hoping to hear but right now HP has several really good systems on sale,
You can use a degreasing spray or methyl alcohol to clean up the residual ink. Use a brush to clean and wipe and BLOW using a hair dryer to fully dry up the residue.
Make sure that there is no dirt at the terminals, clean and set with original cartridges from HP.
Now if there is errors then you must disconnect printer, uninstall then install the driver, connect printer when prompted and print a test page.
Hello, the good news is that it is available to download from the hp website. Just go to http://www.hp.com/support answer the country question, then enter your product name in the box ie 'photosmart 2610' then select 'Software & Driver downloads' and from the dropdown menu select your op sys. Regards nicam49
HP PSC 2410 PhotoSmart All-in-One Q3087A, Q3088A, Q3089A
HP PSC 2500 Series PhotoSmart All-in-One Q3094AR, Q3094A, Q3095A
HP PhotoSmart 7900 Series Printer Q3020AR, Q3020A, Q3021A, Q3022A, Q3023A, Q3024A Q3090A
For HP 0957-2094 PhotoSmart 2410, 2510, 5510 Printers and much more.Come with power cord. Power Rating: 32V 940mA and 16V 625mA Note: Amps and Watts are maximum load tolerance. Devices only draw as many Amperes or Watts as they needed
For purchasing you might also contact this link below: http://cgi.ebay.com/Adapter-For-HP-0957-2094-0950-4466-32V-940mA-16V-625mA_W0QQitemZ250414311173QQcmdZViewItemQQimsxZ20090427?IMSfp=TL090427149005r21586
Make sure power adapter is plugged into a power outlet that you know works. Then try and power drain the printer by unplugging the power cable and letting it sit for a bit and pressing the power button a few times. Then plug the power back in and see if it power up. If not, then the power adapter itself or the internet power on the printer might be faulty.
By self-test, I assume you are doing that manually on the printer. drivers downloaded/installed? right click on my computer, left click on properties, click on hardware, and then click on device manager. is there a yellow question mark by print drivers? If so, then need to load them from the internet or from your installation disk.
also no power....
My 2610 is a few years old - using with XP. Tested the power supply and read 31 volts with a volt meter. But yet the printer is totaly dead.
