All incoming calls go direct to voice mail,phone does not ring.
Firstly I am 74yrs,please advise me how to fix my problem,which I probably caused. All incoming calls go direct to voice mail,phone does not ring. Help!! Regds Margery.
Try going in to you setting and look through them you may have put the call divert to voice mail on . if you have you can unclick it and take it off and that may sort the problem if your stuck ask you service provider to talk you through the steps
You need to know what extension is causing the forward directly to voice mail. Chances are that this extension has ringing lines programmed to it and the forward on busy is to voice mail. ANY PHONE THAT HAS RINGING LINES SHOULD NOT BE SET TO FORWARD ON BUSY. If they happen to be on the phone when a call comes in it will go straight to their personal mailbox.
Panasonic does not have a detailed user manual or download except the quick quide which does not solve any of the problems I have been viewing. I cannot get the link that Carl Navarro posted to work. Anyone else have the very thick manual as a pdf?
Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
This can be handled by the DND feature in your admin settings... Do not disturb will transfer your calls direct to voicemail without ringing the handset.
When I press talk to make a call, it just beeps and turns off, there is no ring tone? There is a new battery and the charge light is lit when the phone is on the base. Please advise.
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
