Emerson MW8102SS 1100 Watts Microwave Oven Logo
Posted on Apr 03, 2017
Emerson Microwave Will Not Heat Food
The microwave will power on, timers work, etc......but it does not heat at all. Ever since we purchased the microwave, it powers off completely whenver cooking certain foods. For example, when cooking baked potatoes (4 or 5 placed in a cirlcle on oven safe plate) the microwave powers off after about 7-8 minutes of cooking; the whole thing powers off, lights and all. It then takes several minutes to power back on. This happens every time we bake potatoes, or pop more than one bag of microwave popping corn consecutively. It almost seems like it just gets too hot. It is positioned in an area with sufficient ventilation, several inches on all sides and top.
5 Related Answers
Anonymous
  • 6784 Answers
  • Posted on Jun 01, 2009
SOURCE: ge jvm1870 it won't heat anything, all other items work
Ok, if this unit has stopped heating, this will confirm a major fault within the Magnetron. this device is responsible for the heating affect and, you will need to replace this damaged part in order to restore proper heating functions in you microwave oven.
VEKAT
Devabhakthuni Venkateswara Rao
  • 225 Answers
  • Posted on Oct 13, 2007
SOURCE: Emerson Microwave MW8102ss
check control panel, may be problem at control circuit.
Anonymous
  • Posted on May 02, 2009
SOURCE: My Microwave does not heat up or cook...
the microwave oven has been working, but all of a sudden it does not heat up.
Anonymous
  • 999 Answers
  • Posted on Aug 27, 2009
SOURCE: BAked Potato caught on fire in GE Microwave
Fuse is behind the control panel. Has cavity sensors and a magnatron thermal disc also. Start with the fuse and then pull it down if not the problem. Eric
Testimonial: "Thanks Eric...now I'll have to find the control panel.I guess you've figured out by now I'm just a girl trying to do a guys job. (smile)"
Anonymous
  • 2992 Answers
  • Posted on Mar 26, 2010
SOURCE: no power to control panel
There's a safety thermostat attached to the cooking cavity in most ovens to detect when something overheats. Once they operate they cut off power to the rest of the oven. These are usually non-resettable, and need to be replaced to repair the oven. If there wasn't any damage done to the interior of the oven you can see about having the repair made.
1helpful
Mic.oven takes longer to heat food
The microwave may not be cooking at full power, check the settings. If okay the magnetron is on it's way out and will eventually fail.
Microwave still lights up and timer still works but it won't heat anything up
The magnetron is the most likely cause, "heats food" this part is the heart of the microwave and expensive. The other two parts to consider is the high voltage capacitor and diode, but repairs will run high depending on the nature of the problem.
Our microwave (GE) not longer heats food items.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r
2helpful
2answers
Emerson MW9111 will not heat- all timers & clock work
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
2helpful
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Power but no heat
heatman101
5oryi
2helpful
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Does not "heat" food.
The Microwave Magnetron or power circuit break down . You need to replacement the parts .
Good luck
Top Emerson Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
