Water is leaking from the bottom of the door. Float is working fine. Drain is working. Is there a way to check and see if it needs new rubber gasket (the lining of rubber around the door and apparantly inside the door. Should I take apart the door to see that?
I realize this is an older thread but I've recently purchased a home with a Blomberg DWT 34240 dishwasher that was leaking from the bottom of the door and I successfully fixed it after trying the tips listed prior here without success.
I replaced the door gaskets and the dishwasher continued to leak. After a more careful examination of the inside it seemed to me that the lower spray arm (part number 1881300400 http://www.encompassparts.com/item/9506703/Blomberg/1881300400/Lower_Spray_Arm_Group ) had some minor damage and may not have been sealed properly. I ordered the new part for just over $4 and paid $8 for shipping from a local distributor.
Upon arrival of the new part I compared them side by side and the problem quickly became apparent. At some point the arm was damaged and at the end of the arm the seal was broken. This little bit of a break in the seal was enough to allow for some bending of the arm which positioned it directly aimed at the lower door seals when in operation. The water pressure forced water through the seals which are not meant to withstand pressurized water but rather standing water only. Since replacing the arm my dishwasher hasn't leaked a drop. I am very pleased because my wife was so fed up she wanted me to either get a repair man or replace it completely and this $4 part just saved me a grand.
I haven't seen this solution listed in any of the repair sites so even though this is an older thread I am hoping someone else will come across the information when they need it and save their dishwasher as well. These things run super quiet so I am happy not to have to get rid of it!
Try checking the Door Gaskets.. It maybe what is causing the problem.
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
uiopety
Hi
The issue is with the water not draining as something might
be blocking the drain pump assembly thus the water is leaking. To solve this
issue you'll have to take the front lower access panel out and then clean the
drain pump assembly completely, also clean the impeller and chopper assembly
located at the bottom of the unit. After this is done the issue should be
resolved, if not then check the float switch mechanism and make sure that is
fine. Hope this helps...please post back for further assistance.
Daniel
