Mother-in-law's Amana model ARB1914 has a 1C11B icemaker that is making small 'deformed' icecubes. I am told that it can be fixed it with heat from a hair drier. However my suspicion is the unit is not getting enough water and the valve may need replacement. Any suggestions or guidance? TIA
Heat guns are typically a bad idea as most people will hold it in one place too long melting,or disfiguring the plastic on the icemaker or worse,the cabinet.
Removing and using hot water is always the best way!
The usual problem for small, or hollow ice cubes is a bad saddle valve. There really isn't a good saddle valve in my opinion as they always clog either from mineral or rusting from the inside out.
What you want to do is find your shutoff valve. Sometimes in the basement, or under a sink if it is close by the refrigerator and look to see how it is hooked up. If it has a valve like the attached pic then it would be best to call in a plumber and have him replace it with a toilet style ball valve which will never restrict water flow and will always work!
The two main types of saddle valves are self pierce (absolute garbage) and drill type. If you look at where the valve straps to the pipe it will either have a round or square gasket. The square gasket ones are the worst and 99.5% of the time are the problem.
SOURCE: amana scd23vw
attempt to pry off the plastic cover over the ice-maker (or look for screws). You should see at least one screw adjustment and clockwise turn is more water.
SOURCE: 11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
SOURCE: Amana icemaker not making ice
Just had the same problem,when I pulled the fridge away from the wall I noticed the copper tubing running from the water source had a kink in it. Got a new line and problem solved it also mentions this in your manual under trouble shooting.
SOURCE: ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
