Endurance E7 Elliptical Trainer Logo
Posted on Apr 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nordic Track elliptical E7: The tension belt came off. It's not apparent how it goes back. Are there diagrams that show the way the belt is attached to the tension cable?
John Mazmanian
Level 3:
President:
  • Endurance Master 832 Answers
  • Posted on Apr 10, 2010
John Mazmanian
Endurance Master
Level 3:
President:
Answers
832
Questions
0
Helped
628608
Points
2056
If you are looking at right hand side of unit you have the flywheel next to it adjusting tension plate.If you have your manual handy it will show how to loosen this part so you may loop over the small idler pulley which goes around the much larger pulley wheel if not here is the web page to go to and its on page 21 Hope this nugget will help!
http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=NTEL07808&version=0&company=11&modelName=NORDICTRACK+E7+SV+FRONT+DRIVE+ELLIPTICAL&language=
2answers
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Extreme noise in elliptical when using
With regard to the clunking in the NordicTrack E7sv it turned out to be the left side wheel to crankshaft connection. It had come loose. I removed the left side foot rods and wheel cover plate for access. I re-seated the wheel on the shaft and tightened the hardware. Noise gone. So is all the squeaking associated with it loosening.
Nordic track a.c.t. classic elliptical belt tensioner
You have to loosen the underside bolt as well as the 10mm bolt on the side . The 10mm bolt locks the adjuster in place. The underside 16 mm bolt is the adjuster.
Nordic track ellipse e7
try to reset and restart again. adjust the REED switch see the diagram attached.
My nordic track 2000 lights come on but will not respond when pushing the buttons
adjust the reed switch, clean it , test for open or faulty, tight the connector very well, see the diagram attached, Replace batteries too
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
My nordic track treadmill 8600 has controller error08 and belt does not move
Dear Sir:
Please run the software calibration that coming with your equipment, see the instructin under the Hood motor, and follow the steps. or user manuals.This will guide your for diagnose and troubleshooting.
See the attached block diagram for troubleshooting and diagnose that I did prepare for customers.sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Missing a part on the tension belt for a Nordic Track Achiever
Go to Iconservice.com click on manual input Nordic Track Skier their is 47 matches the friction band tensioner should have a clear diagram of that mechanism
Top Endurance Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
